backfire exhaust
Old Oct 6, 2004 | 09:51 AM
ultraflip's Avatar
Unhappy backfire exhaust
I recently installed my turboback exhaust system... since then... everytime i quickly shift from 2nd to 3rd or from 3rd to 4th... my car backfires... ((makes a *POP* noise))... i know it's most likely due to the cat delete pipe... but... is it really suppose to do that every time i shift? and just because it backfires like that... doesn't necessarily i'm shooting flames every time right?
thanks for the input in advance guys!
Old Oct 6, 2004 | 09:56 AM
hotrod2448's Avatar
Thats pretty normal from what I understand. My car with just a catback pops when I shift from 1-2 and 2-3. I think it's from the lack of backpressure.
mr0072003's Avatar
When my Cat was dead on my s14, the car began making the same sound that your describing....i kinda liked it, but as sson as the Cat and leak were fixed, problem went away.
Old Oct 6, 2004 | 09:58 AM
bolsen's Avatar
Yea it could be a leak.. it's just fuel exploding in your exhaust.
On my old jetta if I would time my shifts just right I'd get a huge *POW* outta the exhaust... I thought it was the greatest thing ever
Old Oct 6, 2004 | 11:36 AM
ultraflip's Avatar
bolsen... you stated exhaust leak...
so would i just have to check my gaskets and tighten my bolts from the engine-dp, the dp-test pipe- and testpipe-cat-back??
Old Oct 6, 2004 | 01:03 PM
kdogg's Avatar
The exhaust does make a "pop" sound when you release off the accelerator. It's normal. It pops on a stock exhaust too, but it's barely audible. A "backfire" occurs when it pops while pushing the accelerator. If you get a "backfire", then you have some problems.
Old Oct 6, 2004 | 02:25 PM
ultraflip's Avatar
kdogg... what kind of problems are you referring to?
my car "pops" after the shift... when releasing the clutch and getting back on the accelerator... during that initial point... *pop* goes my exhaust... how does this impose a problem?
Old Oct 6, 2004 | 02:32 PM
Streetrcrm3's Avatar
Go to a shop and get it checked out if your really concerned; your syptoms to seem to be pretty common with going catless.
Old Oct 6, 2004 | 03:00 PM
ultraflip's Avatar
i would normally go to a shop to verify my problems... yet being catless in california... many shops tend to frown upon such a thing... that's why i'm turning the evom community to help me in this turmoil
Old Oct 7, 2004 | 06:12 AM
kdogg's Avatar
Are you getting the pop while flooring on the gas? It sounds like you're getting it when you're shifting which is normal. I'm not engine tech or mechanic, but someone else can chime in to why a car backfires when stepping on the gas.
Old Oct 7, 2004 | 07:16 AM
bigric09's Avatar
mine does it now also i am turbo back its mainly when i accelerate and let off, but i know my spark plug isn't firing correctly, you may have the same issue... clean your plugs and test
Old Oct 7, 2004 | 09:06 AM
ultraflip's Avatar
would i really have problems with my sparkplugs with only 7k miles on my car?
Old Feb 22, 2005 | 06:48 PM
ThEHiTMaN's Avatar
Mine does it also. It does it on part throttle shifts. As soon ans the clutch goes in it pops. Clutch in while i am on my way to 2nd or 3rd or 4th it pops but by the time i get it in the gear and let the clutch out it's done. Just curious about the flames? I have noticed that cars don't trail close behind after it happens a vew times... Usually on my way home from work after the car has warmed up a bit.
Old Feb 22, 2005 | 06:53 PM
felo3769's Avatar
I had that on my Z when I changed my exhaust, and I had test pipes on. I took off the exhaust cuz it was too loud, but I liked the pop sound. I actually had some real "backfire" coming out of the exhaust. I have a video if anyone wishes to see
Old Feb 22, 2005 | 08:02 PM
boostedwrx's Avatar
hmm i dont get any pop or exhaust backfire. I have the UR 3" with test pipe...
