View Poll Results: What do you think on this topic?
Hell yeah! The EVO needs a new powerplant!
60
10.87%
I guess they should change it...
37
6.70%
Don\'t know
34
6.16%
Nah, why should they change it?
105
19.02%
Hell no! This is the best engine to use in the EVO!
316
57.25%
Voters: 552. You may not vote on this poll
4G63... outdated and archaic?
Old Dec 7, 2004 | 05:53 PM
  #181
Fenris Ulf's Avatar
Originally Posted by VtexGt3
just rumors, plus hsant mits had MIVEC for a while now? i mean its not on the WRC evo... so i guess they have no use for it... then it wont be on the normal evos either..
WRC Evos make positive boost at idle dude. Apples to oranges....
Old Dec 7, 2004 | 08:48 PM
  #182
4G63>OOOO's Avatar
So can your Evo, if you setup an antilag system via standalone.
Don't ask me how I know this and holy hell, is it loud!
Old Dec 9, 2004 | 05:17 AM
  #183
chuntington101's Avatar
its easy (haha), all the standalone dose is set the timimg back so it fires when the exhaust valves are open. then the fuel air mixture (still pump in fuel) that has left the cylinders is ignited in the space between the vavles and the turbine (you need to set the timing so the valves are just starting to close). so you have a BIG bang in a very small space causing loads of presure and driving the trubo.
problem is these big bangs are like hitting the turbine with a hammer, but rally guys dont mind forking out for new blowers after each event!
thanks Chris.
Old Dec 9, 2004 | 05:30 AM
  #184
ShapeGSX's Avatar
Actually, it isn't quite that easy. You need an air bypass to get anti-lag while the throttle is closed. Fuel without air will not burn.
Old Dec 10, 2004 | 05:16 AM
  #185
shape mate, the group N guys over here do it just fine with their stock (yeah right) EVOs. i think there is enough air flow when the throttle is closed. alternativly, you could just flat shift and set the ECU up to soft limit when the clutch is pressed.
the best Anti-lag system i have seen was on a Ford RS200 EVO2. that wented to boosted cold air into the exhaust, to help the turbo along, then when you realy wanted it you could turn the conventional anti lag on! so you cot loads of cold air and fuel in the exhaust mani, and a very big BANG. hey presto, NO lag.
i would still go for a supercharger and turbo though!
Chris.
Old Dec 10, 2004 | 05:22 AM
  #186
ShapeGSX's Avatar
How can there be airflow with the throttle closed?
The pre Evo VIII's had a bypass valve installed on them with metal lines running to the exhaust manifold. That is the reason for the big stubs of metal between cylinders 1&2 and 3&4 on the exhaust manifold. Those are the bosses for the air lines going to the exhaust manifold for the anti-lag. The anti-lag just wasn't turned on in the ECU. Perhaps the group N guys have it turned on?
Old Dec 10, 2004 | 08:45 AM
  #187
GPTourer's Avatar
Is that what all the mis-firing and backfiring is all about?
Old Dec 10, 2004 | 09:24 AM
  #188
wingless's Avatar
noob dream motor:
-2.0l, I4
-direct fuel injection
-electric servo actuated variable valve timing
-dry sump lubrication.
-individual coil packs
Old Dec 15, 2004 | 04:51 AM
  #189
Originally Posted by wingless
noob dream motor:
-2.0l, I4
i would just add a few things wingless,
BIG bore/short stroke 2.0ltr I4 (with room for a long throw crank when you need to mod)
Ti rods.
forged pistons, or VERY well made cast.
coated chambers
4 vales per cylinder with air valves.
super strong ally block and head with through bolts for ultamate strength while keeping weight down.
equal length cast or tube manifold, coaded inside and out.
and as above
thanks Chris.
Old Dec 16, 2004 | 01:37 PM
  #190
RKT SHP's Avatar
i think they should keep the engine the same it is a proven engine. so why mes with a good thing
Old Dec 19, 2004 | 03:45 PM
  #191
slushfund's Avatar
They need to improve the 4G63 w/o complicating the after marker tuning possibilies.
I agree with dry sump lubrication, improved ignition, and direct injection.
Dry sump allows lower in the engine mass, but increases the manufacturing costs.
Improved ignition improves the current EVO and appears in their competitor's new models.
Direct injection is the future. Mitsubishi has been working on this since the 1990's. BMW is using it in the new M5. Check out this Mitsubishi direct injection site, http://www.mitsubishi-motors.co.jp/i...GDI/page5.html
Old Dec 27, 2004 | 12:22 PM
  #192
evolution9's Avatar
all we need is a bump in displacement, 2.5L would cure our power woes
Old Dec 27, 2004 | 12:56 PM
  #193
NOVA EVO's Avatar
Naah...just get a bigger turbo...
Old Dec 27, 2004 | 02:13 PM
  #194
ShapeGSX's Avatar
Who has power woes?
Old Dec 28, 2004 | 07:13 AM
  #195
4G63>OOOO's Avatar
More like torque woes. :P
