What i/c pipes work with the stock intake?
Old Nov 4, 2004 | 08:04 AM
marksae's Avatar
Yeah, it's that aluminized steel, which is just mild steel w/ the aluminized coating on the surface to slow down the rusting process.
From my experience, I've also noticed that fitment isn't the greatest either. They definitely do not have the "fit like OEM" feel to the parts, meaning they may require slight tweaking to make work.
Old Nov 4, 2004 | 08:17 AM
Eric Lyublinsky's Avatar
Just get the samco hoses. The stock piping is not that bad. Lower IC pipe makes the most diffrance and that's only a few ponies. The Samcos will not balloon as much and will not slip of the piping. Great units.
Old Nov 4, 2004 | 08:45 AM
boostfed's Avatar
How do the samco hoses do with heat soak. I remember my factory hoses would heat soak and stay hot forever. Now with injen IC piping. at the dragstrip I can make a pass then pull back in the lanes and pop my hood and if I have 10-20mins(depending on outside temp) between passes. it would be back down to almost outside temp...
-chad-
Old Nov 4, 2004 | 08:48 AM
-chad-
Chad,
Never thought of that. I would assume it would be the same as stock if not better because there is no covering like the stock units. I have not had a IC heat soak problem but I also live in the NE.
Eric
Old Nov 4, 2004 | 09:19 AM
marksae's Avatar
My guess is that the samco hoses will dissipate heat faster compared to the stock rubber hoses since they are much thinner. Rubber is an insulator and will dissipate heat at a much slower rate compared to aluminum. The samco hoses should fall somewhere in between the two.
Old Nov 4, 2004 | 10:31 AM
Zeus's Avatar
It will be interesting to see what will be coming to the market in the near future...
rage mang
Oct 24, 2016 06:12 PM
McDougal
Aug 3, 2012 09:27 AM
ugakirk
Feb 18, 2012 04:28 PM
smgevo
Nov 15, 2008 03:11 PM
*chris*
Automotosports - Illinois
Feb 20, 2006 12:33 PM
