How to achieve a 94 Octane tank via 91 Pump
Old Oct 17, 2004 | 07:46 AM
ArchieBabes's Avatar
How do you achieve a 94 Octane tank via 91 Pump gas?
What is the correct formula if you mix 91 with 100 race gas?
I want to get a full tank of gas resulting in a 91 and 100 race gas mix.
What is the ratio?
8 Gallons of 91 mix it with 5 Gallons of 100 Race gas?
Will this result in a 94 Octane rating?
Old Oct 17, 2004 | 08:36 AM
marksae's Avatar
Mathematically, you can use this formula to equate the ratio of 91 vs. 100 octane you need to get an equivalent of 94 octane in your tank.
91X + 100Y = (X+Y)94
where X = # of gallons of 91 octane
where Y = # of gallons of 100 octane
The ratio you end up with is X/Y = 2/1.
So you just need to fill up 1 gallon of 100 octane for every 2 gallons of 91 octane to get 94 octane. This is assuming the octanes mix linearly.
Old Oct 17, 2004 | 08:46 AM
Thanks marksae...
I can't turn up my boost to 23psi when using 91 gas.
How much do you think the prices are for a gallon of 100 race gas?
Old Oct 17, 2004 | 08:49 AM
Kuba23's Avatar
Originally Posted by ArchieBabes
Thanks marksae...
IN NJ its about 6-7 bucks a gallon
Old Oct 17, 2004 | 08:59 AM
marksae's Avatar
Wow, 23psi on 91 octane seems pretty high. Is your car tuned to run that much boost on 91 octane? I hope you have an EGT gauge or some sort of way to monitor knock.
I haven't bought race gas in a few years, but when I did, it used to cost $6-7 per gallon.
Old Oct 17, 2004 | 09:16 AM
marksae,
No 23 psi is on 94 Octane
And 21 psi on 91 Octane
I have it set on my UTEC map, so I just switch between them and turn up the boost accordingly.
Old Oct 17, 2004 | 09:27 AM
simevo's Avatar
Hope you're not doing this everytime you fill up your tank cause in the long run it would be better to invest in a new turbo kit ($2000) or a water injection ($900) imo.
For me with the amount of miles I drive, it would cost me about $1100 a year to mix gases everytime I go to fill up.
Old Oct 17, 2004 | 09:31 AM
naucrx's Avatar
((91*9)+(100*5)) / 14 = 94.21 gallons
You would need approx. 5 gallons of 100 octane to get a 94 octane mix.
I have used 110 octane leaded before, which boosts the octane even more. I had a 98 octane mix in the tank and I turned the boost up to 23psi.
91 **** gas is so crappy!
Old Oct 17, 2004 | 09:39 AM
simevo's Avatar
Gasoline companies are just raping Californians. Not only do we pay the most expensive gas in the country but they only give us the crap 91 octane while some other states get the 93 and pay less.
I wouldn't mind paying the highest gas price in the country but give us 93 or 94 octane.
Old Oct 17, 2004 | 09:42 AM
marksae's Avatar
No sh*t!! I just paid $2.70 per gallon yesterday! $33 to fill up my tank. ouch..
Old Oct 17, 2004 | 10:00 AM
EVO8LTW's Avatar
Is it illegal for stations to sell higher than 91 in California? Seems like there's a huge business opportunity there to sell pump 93 imported from out of state as cheap "race gas." Buy it for $2.00 a gallon in the next state over and then sell it for the going price of 91 in CA plus maybe a dollar ($3.75?). There must be something illegal about doing that. Otherwise, I'm moving to CA and opening up a gas station
Old Oct 17, 2004 | 01:35 PM
AcA's Avatar
AcA
You guys should ask the terminator to do something about it...
Old Oct 17, 2004 | 07:31 PM
Nellie's Avatar
I think it's a State mandate that we only get 91 octane and gas companies charge a higher price because we have add all those great additives to make our gas more healthy (MTSBE / Ethonal / etc.).
I'm sure they're not slow to inflate prices when possible. I'm also sure the State is not doing a good job in making them be more price competitive - something along the lines of "We're one of the biggest (if not biggest) users of automobiles and therefor gas. If you'd like to do business in our State, you need to use the folowing octane formula, include the following additives and not charge more than the average price per gallon of the other forty none states."
Seems so simple, doesn't it?
- Nellie
EvolutionRacing
Jan 18, 2016 09:55 AM
blueprint
E85 / Ethanol
Sep 29, 2014 03:53 PM
Kidloco51
Aug 22, 2011 05:49 PM
EVO8URV8
Dec 26, 2007 08:01 AM
MalibuJack
Northeast Region
33
Feb 22, 2004 09:07 AM
