Low Oil Pressure Readings
Old Dec 5, 2004 | 05:33 PM
03venom's Avatar
I have the bf OP... I see 80 - 100 KPA when the car is warm and idling. It's perfectly normal. You should see 400 - 700 KPA under any sort of acceleration.
Old Jan 1, 2005 | 06:39 PM
FresnoEVO's Avatar
mine does the same thing, defi bf gauge, i just set the warning on the link unit a bit lower and now i have no probs.... good thread... i was having the same concerns
Old Jan 1, 2005 | 11:49 PM
JTB's Avatar
JTB
Just a follow up:
My last oil change I switched to Red Line 10w40. Due to the higher temp oil I no longer have this problem.
Old Feb 20, 2010 | 11:42 PM
tchouko's Avatar
Originally Posted by 90GSX-03EVO
When I drive the car with the RPM's staying over 5000 for a sustained period of time, this is usually the type of indication that I see on my oil pressure gauge.
I think i just experience that tonight...cause i was driving a bit over the sane rpm for a good period of time...and now my oil pressure gauge is down to 0 and it's flashing?
any ideas as to why it does that...do i also need an oil change cause i'm due for a new one...
Old Feb 20, 2010 | 11:52 PM
teudmunki9mr's Avatar
bump for curiosity on fix
Old Feb 21, 2010 | 12:05 AM
Crazy K's Avatar
Well I use a greddy block that sits between the filter and block and with my defi gauge hooked up I get bout 18ish psi when fully warmed up at idle which is 950rpms and I'm using 10w30 mobile 1. On cold start ups its very high due to cold oil and even when its fully warmed up WOT puts out very high pressure as well,
I think it depends on where you tapped your sensor in for oil pressure, tappin in at different places will give varying results under differenct conditions.
Mohamed Medhat
Feb 18, 2017 11:33 PM
deza3000
Oct 4, 2015 11:09 PM
Apex Hunter
Sep 15, 2015 10:21 AM
Shizzle
Dec 13, 2009 08:32 PM
Profoxcg
Oct 1, 2007 07:26 PM
