clutch slipping or ?
Old Oct 24, 2004 | 03:20 PM
dizzigital's Avatar
clutch slipping or ??????????
Hey guys,
I recently noticed something severely wrong with my car sometimes in third gear, but mainly when I'm in fourth and fifth gear. This happens too often to ignore and only noticed when I'm on the freeway. I'm approaching the 11,000 mile mark with the fluids changed regularly and no abuse to my beloved EVO. Both brake and clutch pedals feel to have lots of life remaining.
I'm cruisin' at about 3,000 RPM or so and then decide to floor it. The RPM's go up another 1,000 or so, FLUTTER and maybe even drop a little before deciding to start rising again. It sounds as if my clutch is slighty engaged and makes me want to reach down and pull my clutch pedal out. Is this the infamous "clutch slip"? If not, then what is it??
-Robert
Old Oct 24, 2004 | 03:30 PM
Evolboost's Avatar
If you didn't touch the clutch from when you were cruisin to when you floored it, my guess it's your clutch. But I'm no mechanic. Bump for ya.
Old Oct 24, 2004 | 03:40 PM
dizzigital's Avatar
Is there any chance these could be symptoms of the Misfire Recall on '03s?
Old Oct 24, 2004 | 04:06 PM
dizzigital's Avatar
BUMP.
Old Oct 24, 2004 | 04:36 PM
dizzigital's Avatar
BIG BUMP. Assistance is needed!!
Old Oct 24, 2004 | 04:38 PM
SaitouhHajime's Avatar
It sounds like the clutch is slipping, thats pretty much what my clutch did when it started to go although for me it was more noticable in 1st and 2nd gear than the later gears. just my 2 cents, good luck with whatever it is
Old Oct 24, 2004 | 04:40 PM
legal-z's Avatar
it sounds like your clutch. the best road test to determine this is to get on the highway, put the car in 4th and cruise. when your is at about 3k rpms, depress the clutch and rev the motor. dump the clutch at between 4k and 5k rpms. if the revs don't drop right back to 3k immediately your clutch is slipping. i know this may sound a little harsh but doing it once or twice won't hurt anything. if the revs go right back to 3k you have another problem.
Old Oct 24, 2004 | 04:41 PM
dizzigital's Avatar
hmmm... there's seems to be a lot of clutch left tho. =/
Old Oct 24, 2004 | 04:43 PM
dizzigital's Avatar
ahh... good idea. ok, and what if they drop right back down to 3?
Old Oct 24, 2004 | 04:51 PM
Sano's Avatar
If its your clutch it will keep getting worse and worse. Soon you will give it gas and it will jump 3-4k before engaging. Then you can go to mitsu and get kicked in the nutz when they tell you the will not cover it.
Old Oct 24, 2004 | 04:52 PM
dizzigital's Avatar
SPLENDID. I'm not about to burn $1,400 on something that should last for YEARS.
Old Oct 24, 2004 | 04:55 PM
dizzigital's Avatar
any other thoughts?
Old Oct 24, 2004 | 04:57 PM
legal-z's Avatar
if they drop right back down then it's not slipping.
Old Oct 24, 2004 | 04:58 PM
dizzigital's Avatar
oh ok.. but what's this?
Old Oct 24, 2004 | 05:15 PM
dizzigital's Avatar
bump me please
Fireescape
Jul 4, 2016 11:18 PM
Evo_Goodness
Jun 28, 2016 11:29 AM
evo robert
Sep 2, 2015 09:29 AM
Uscbryan
May 22, 2015 08:21 AM
FastAzzEvo
Jun 8, 2007 02:48 PM
