Clutch question slight rattle
5So everything on the EVO is new to me when i am in neutral i have a rattle from my transmission a very noticeable one the sound completely goes away if i push the clutch to the floor or half way point even the sound is not there, if i am driving no other clutch issue no slipping no nothing a little bit of chatter when starting from a stop in the morning when cold. I'm not 100% sure if its a stock clutch but I'm guessing no but here is the funny thing if while sitting in neutral if i pump the clutch a couple of times the sound pretty much goes away or is very faint till i push the clutch in all the way again i don't even need to pump it all the way to the floor the half way point will kill the sound..
First i thought it was a slight motor knock but its not as soon as i push the pedal to the floor it goes silent i was thinking maybe throw out bearing is rattling around or something lol maybe gear rattle if it is gear rattle will a fluid change help.
Maybe clutch adjustment ?
Likely no problem. Pretty sure most of our clutches do the same. Slight noise, rattle, at idle, in neutral.
When depressing the clutch, the rattle goes away. Something to do w/the throwout bearing & its normal operation
Ya it's weird I can get the sound to go away if I pump the clutch a couple of times while in neutral it almost goes silent I've also noticed the warmer it is or the longer I drive it the quieter it gets
Ya I'm going to get it up on some stands this week and look in the inspection plate the thing that's weird is if I pump the clutch 2/3 times and let off it the sound goes away then comes back when I push it in again and let off it almost like I bleed something when I pump it and it puts pressure against whatever is rattling under there
reboundicon
May 3, 2017 11:51 AM
Rob_GPT
63
Apr 6, 2011 09:21 PM
