View Poll Results: Best cam combo
HKS 272/272
47.08%
HKS 264/264
20.76%
HKS 264/272
23.39%
Works 269/269
8.77%
Voters: 342. You may not vote on this poll
Best cam combo poll
Old Oct 28, 2004 | 09:37 AM
  #61
Ted B's Avatar
Here's what one can do with a bit of cam timing:
https://www.evolutionm.net/forums/at...chmentid=45864
The cams are an HKS 272 set. The graph in red is a -3/-3 setting. The blue line is a -4/-1.5 setting. These runs were done back-to-back. The 300whp mark on this dyno = 350whp on a Dynojet.
Notice how the longer overlap setting (red) makes the car come on boost quicker, while the lower overlap setting spools a little later, but is a little better on peak power. Now, with a bigger turbo that can hold boost in the upper rpm ranges, one could use the lower overlap setting and really optimize power, which would be beneficial for drag racing.
For auto-x, one could use the high overlap setting and even advance both cams an equal amount (like 2-3 degrees), which would bring in the boost even earlier, and generate a wide, flat power curve that's good for blasting out of the corners.
Mods on this car: Vishnu Std turbo-back 3", 10.5t turbo, Xede +Xede-flash, AMS lower IC pipe, 255 lph pump, HKS 272, Vishnu cam gears, Helix O2 housing, 650cc injectors. Car has stock IC and has a catalytic converter.
Old Oct 28, 2004 | 09:41 AM
  #62
woobos's Avatar
I have a set of tomei 280/ 11.5mm lift procams. Kind of nervous to try it out. It'll go into a BJCH Stage 5++ head next week.
Old Oct 28, 2004 | 10:07 AM
  #63
2k4EvoVIII's Avatar
Hmm i was pretty sure that the Tomei come in the following configs
260 with 11.5
270 with 11.5
280 with 11.8
Chris
Old Oct 28, 2004 | 11:13 AM
  #64
boostfed's Avatar
after looking at the Chart. It seems to be a good amout of adjustablity with the camgears on the 272's. How hard is it to adjust cam gears. Is there anywhere I can read about it. Like I said earlier, I have never messed with cam gears and would like to read up on it. I guess I'll do a search. keep on posting this good information.
-Chad-
Old Oct 28, 2004 | 11:28 AM
  #65
woobos's Avatar
260 with 11.5
270 with 11.5
280 with 11.8
Chris
Its 280 duration 11.5 lift just like the other procams. Do you think its wise to go with these?
Old Oct 28, 2004 | 01:52 PM
  #66
Laser2Talon2Evo's Avatar
Great thread so far. Thanks for making decisions that much easier and handing out some free knowledge. Much appreciated by all.
Old Oct 28, 2004 | 02:02 PM
  #67
VTECH8TR's Avatar
-Chad-
Heck it's Easy to adjust cam gears, just make sure you tighten all the bolts back up.
Old Oct 28, 2004 | 02:06 PM
  #68
boostfed's Avatar
yeah I figured that out once I did a little search. My only other question is how with this efect my car especially once I get it tuned. Should I just setting one way and leave it that way or can I adjust it accordingly ( if I'm gonna be autoxing or dragracing.) I guess I'm really gonna have to invest a little time and money into a piggyback tuner and some datalogging.
-Chad-
Old Oct 30, 2004 | 12:01 PM
  #69
MrBubbler's Avatar
http://www.socalevo.net/forums/viewt...er=asc&start=0
Old Oct 30, 2004 | 12:07 PM
  #70
EVO32570's Avatar
Has anyone tested settings for cam gears with 264's????
Old Oct 30, 2004 | 12:27 PM
  #71
Ted B's Avatar
Those test results are compromised and should not be regarded as accurate.
Old Oct 30, 2004 | 04:26 PM
  #72
gofaster87's Avatar
How are they comprimised?
Old Oct 30, 2004 | 04:33 PM
  #73
Ted B's Avatar
Have a look at the A/F curves and look carefully at the lines in the power curves for the Piper cams. Tell me what you think.
Old Oct 30, 2004 | 04:39 PM
  #74
jfh's Avatar
jfh
How would this setup compare with the 264/272 HKS combo dialed in at -3/-3?
Old Oct 30, 2004 | 04:49 PM
  #75
Ted B's Avatar
At the same setting, the 264/272 combo should give very comparable results to the 272 set, with spool up ocurring about 100rpm later and a peak power curve that tapers just very slightly sooner.
