my clutch is starting to die at 2k
Your flywheel is ruined. If you have no mods you might luck out like I did. I took my car in for the TSB on the 5th syncro and aksed if they would go ahead and replace my clutch and flywhell.. they are doing it for just one hour labor. I bought The ACT MB7-HDSS set (pressure plate, disk, and throw out) for $479.97 and the Fidanza light weight f/w for $350.00. You need a stronger clutch than the one I bought if you are going to race your car on the strip (I just road my car). Check out the deal at RRE, and get with your dealer on the TSB on the 5th gear syncro sleeve.. (just tell them it grinds going into 5th). Good Luck
Originally Posted by burningmoney97
how can you tell if the flywheel is bad 2?
Originally Posted by RalliartJP
Learning stick in an evo, ouch..I have a Ralliart and I thought that was a bad car to learn stick on... Look into a carbon fiber clutch if your gonna be that abusive.
- but when it comes to launching it at the track , thats a different ball game
-is a carbon fiber clutch really worth its price tag?
The burn marks a blue steaks or worse visible on the back side (block side). I just saw mine last thurs. My disk thickness is fine and but I suspect the pressure plate isn't. I had absolutely no slippage other than the three times I smelled it burn and these were not race related. Once was on a steep heooo wiht a stop at the top, onec when I needed to go from feverse to first real qucik in an emergency situation and the other was when I blew it and let a friend drive. My car has 1100 on it now.
If you burn out your clutch at 2k miles, then your flywheel will be glazed over. You might be able to get away w/ resurfacing- i.e. cleaning your flywheel anyway, think of clutch/flywheel like brake pad and rotor-
also if flywheel is glazed, then you might be able to salvage clutch, with a light scuffing of surface as well- i wouldn't do this on such an expensive car though- the above methods are usually for beater cars that you want to just last a little longer- kinda like banging your starter w/ a hammer when it's worn out- just temp until you get a new one.
[WTB] Clutch pedal stopper
detroit pistins
Feb 19, 2017 06:50 PM
FS[MidWest]: Exedy twin disk clutch
vipevo9
May 16, 2014 06:23 PM
OX
Nov 19, 2003 11:40 AM
