trouble downshifting at lower speeds on an evo
Old Nov 2, 2004 | 10:00 AM
bluebanana23's Avatar
Do any of yall have trouble downshifting at lower speeds? I have trouble downshifting from third to second when i'm slowing to 10 miles an hour. Same goes for first gear. Whenever it doesn't go in and I force it in, it grinds. I drove a s2k,civic,miata,celica and it doesn't shift like that. So is this normal for the evo?
Old Nov 2, 2004 | 10:03 AM
exhaust_note's Avatar
just keep the clutch in.... put pressure on the shifter towrds the gear you want to go in, but not forceing it in.. and then the shifter willl just fall into gear.. just don't force it...
Old Nov 2, 2004 | 10:07 AM
slt's Avatar
slt
but then when you take it in for warranty work, they look at you syncros and say that you've been speed shifting and tell you to go fly a kite.
Old Nov 2, 2004 | 10:31 AM
WildRice's Avatar
The first gear syncro seems pretty weak and will often grind if you try to down shift at any thing near 4k. I have had no problems with it at low speeds. Some owners have seen improved performance using Penzoil syncromesh in place of the Mitsu lube. If you are only having the problem when you first start driveing it is just that the tran.s needs to be warmer, this is real common in Getrag boxes too and they aren't cheap.
Old Nov 2, 2004 | 11:21 AM
rsboy's Avatar
I read that 1st and 2nd gear are double or triple synchroed so they are harder to shift into. I sort of had that problem when I just got the car, but now it seems to have soften and gotten easier to drive. But definitely try to get use to the clutch. I find you really need to press it at least half way down for it to engage.
good luck!
Old Nov 2, 2004 | 01:13 PM
4-BNGR's Avatar
Double Clutch (aka) Rev Match
That will solve all your problems
Old Nov 2, 2004 | 06:04 PM
boostedwrx's Avatar
double clutching involves rev matching though as you are blipping the throttle before you go into your last throw.
If your trying to get into first, give it a good double clutch and your syncros will all lign up, letting you get into first the way it was meant to.
If your trying to just downshift into third or fourth, just rev match it ie - blip it in neutral - on your throw into the next lower gear.
targa ten
Mitsubishi TC-SST Discussion
10
Apr 3, 2011 12:50 AM
cobra
Lancer Tranny/Drivetrain Tech
11
Oct 24, 2006 06:01 PM
arpad
13
Oct 6, 2005 01:06 PM
apexeight
20
Jan 26, 2005 08:20 PM
en1gma19
European Forum
May 24, 2004 07:58 PM
