Down pipe touching oil pan
Old Nov 2, 2004 | 12:24 PM
plokivos's Avatar
How bad is this when the down pipe is touching the Oil pan?
I have this downpipe that someone made and it's touching the oil pan without the heat shield.
Thanks.
Old Nov 2, 2004 | 01:08 PM
RallySport Direct's Avatar
Silver Sponsor
I would definitly either replace the downpipe or find a way to get it away from your oil pan. Your EGTs in that area depending on your mods could be around 800 deg F. That pipe is going to be very hot and transfer into your oil pan.
Ben
Old Nov 2, 2004 | 01:12 PM
evoego's Avatar
Registered User
mine wanted to touch at first, A little prying action will fix the prob. Luckily the UR downpipe has the flex in it.
Old Nov 2, 2004 | 01:23 PM
Grog's Avatar
Definitely don't want it touching. It's especially bad if you do any track racing. Can you pry it away a little bit? If you can get enough clearance you could heat-wrap the downpipe to prevent some of the heat transfer.
Good luck.
Old Nov 2, 2004 | 01:33 PM
rcrecevo's Avatar
I have the Apexi 3" downpipe and it fits perfect. The pipe comes with the heat wrapping to keep heat away from the oil pan.Everything fit perfect and like some pipes ,this one doesn't need a different support bar.
Old Nov 2, 2004 | 02:15 PM
snoop's Avatar
Thanks.
Try adjusting the pipe there is usaully a little play if you redo the bolts Also kartboy bushing will help.
Whats up with homemade DP I thought you had the Bling Bling?
Old Nov 2, 2004 | 04:58 PM
plokivos's Avatar
lol. It's doug's exhaust.
Old Nov 2, 2004 | 06:24 PM
plokivos's Avatar
whats the consequences of having the downpipe heating up the oil pan? I've had it for a while and went racing with it.
I need to know! lol
thanks.
Old Nov 2, 2004 | 10:25 PM
Cash Money's Avatar
bad...... get a properly made dp and wrap it... that's all there's need to know...
Old Nov 2, 2004 | 10:55 PM
BuLocal's Avatar
Heating the oil = bad. It will break down faster and protect your engine less. Buschur used to have some kind of heat shield or you can get a wrap kit from Summit.
Old Nov 3, 2004 | 01:57 PM
plokivos's Avatar
Thanks guys, i've decided to get a new setup.
CO_VR4
Dec 5, 2016 10:26 AM
yellowevo82
Dec 15, 2013 06:18 AM
chuysralliart
Aug 11, 2011 09:43 AM
aceinthesky2002
Jan 4, 2008 04:37 PM
jeffbum
May 27, 2007 10:56 PM
