explain to me this fuel cut
Old Nov 7, 2004 | 10:45 AM
honki24's Avatar
Originally Posted by Speedlimit
It is the combination of boost pressure (relative to atmospheric), outside air temperature and the amount of air you are sucking. When all three values exceed their setpoints, you get fuel cut. That is why we have and will see more reports of fuel cut as the temperatures lowers in the north with the onset of winter.
The recommended path is to add proper supporting mods (as other stated above) then an ECU reflash, piggy back or aftermarket ECU.
Speedlimit..
so... you say if outside temp....exceeds the setpoint you get fuel cut.. but you say that as temp lowers we will see more fuel cuts? by exceed you mean the temp setpoint is a min rather than a max?
Old Nov 7, 2004 | 02:13 PM
plokivos's Avatar
fuel cuts at 7300 RPM. But ECU Boost cut is probably doing all this. You need a AEM EMS or something similar to get rid of this. even boost controller will do this, electronic one.
isnake
Apr 9, 2017 02:01 AM
xexitenglishx
25
Jan 16, 2011 09:00 PM
machron1
Mar 14, 2008 12:42 AM
krillin
Feb 6, 2007 10:01 AM
Noize
29
May 20, 2005 12:00 AM
