View Poll Results: Do you prefer 5 spd or 6spd?
5spd
38
55.07%
6spd
31
44.93%
Voters: 69. You may not vote on this poll
5spd or 6spd?
Old Nov 14, 2004 | 01:35 AM
bmaga123's Avatar
Question 5spd or 6spd?
Which transmission do you prefer 5spd or 6spd and why?
Old Nov 14, 2004 | 01:43 AM
mrbkkt1's Avatar
not many of us have ever driven a 6 speed, i only did when test driving the g35 and i didn't drive it hard enough to get a good impression, but i guess 5 speed is good enough for me cause i figure when racing, you usually only use the first 4 gears most anyway.
Old Nov 14, 2004 | 01:44 AM
mrbkkt1's Avatar
besides, the more shifting you do, the faster your clutch wears out right? and us evo owners need all the clutch life we can get anyway.
Old Nov 14, 2004 | 02:44 AM
wtz's Avatar
wtz
If you plan to roadrace the car, the 6 is a must. Much better 5th gear. Think about climbing the hill to the bus stop at the Glen with the 5-speed and you will instantly know what I mean.
Cheers,
Old Nov 14, 2004 | 05:09 AM
badlooser's Avatar
Cheers,
I agree with the stock setup 5th gear is terrible I was very unhappy I am sure the 6 speed helps this out.
Old Nov 14, 2004 | 07:20 AM
Noize's Avatar
EvoM Administrator
The 6 speed. The 4-5 upshift on a stangard Evo tranny is an acceleration death sentence.
Sentinal's Avatar
Ive driven several cars with 6 speeds and tons of 5 speeds. I like the 6 speed because it usually has slightly higher top gear ratio which is really nice for freeway driving and it has closer gear ratio's which makes it easier to stay in the power band.
Old Nov 14, 2004 | 08:22 AM
Ang Wen Yan's Avatar
I think 6 speed is better
Old Nov 14, 2004 | 08:34 AM
Evilution VIII's Avatar
Since the USDM '05 GSR and MR share the same ACD are the transmissions swappable?
I posted this a few weeks ago but no one responded.. probably because no one really knows for sure yet....and also anyone know if Ralli-Art's ACD computer works with our USDM ACD systems?
Kyle M.
Old Nov 14, 2004 | 11:15 AM
TurboWill's Avatar
I liked the six speed on my STi. I like the five speed better on the Evo because you have to shift less.
___________________
Rally Red EVOVIII
Old Nov 14, 2004 | 12:04 PM
feldguy's Avatar
The Evo "GSR" of the USDM doesn't have ACD, only the MR. The trannies Im sure are swappable, but how easy, I do not know.
Old Nov 14, 2004 | 01:20 PM
bbbwrx's Avatar
I have heard that the EVO 5spd is stronger than the MR 6spd. I haven't seen any true test on it but the 5spd is supposed to hold more torque.
Old Nov 14, 2004 | 01:43 PM
RuEvolved's Avatar
Its called Double Clutch'n...and it works..youll be stuck to your seat.
Old Nov 14, 2004 | 01:52 PM
Derek Baker's Avatar
2005 Gsr
I believe that the 2005 Evo does have ACD. The 2005 does not have AYC. So I would believe that they can be swapped.
Derek
Old Nov 14, 2004 | 01:54 PM
watchout's Avatar
The 5 speed is supposed to a much stouter transmission, especially if you are into drag racing.
Shane
