turbo upgrade
Old Nov 14, 2004 | 11:05 AM
craigbb's Avatar
turbo upgrade
if you are limited to using 94octane gas what is the benefit of adding a larger turbo on ev08? lets say if the motor is built to take advantage of it with all the stg upgrades,racing head stg3,forged internals etc..boosting beyong 20psi wont be able to happen anwyay with pump gas..question is can a larger turbo provide more HP using the same boost as the stock turbo..i was thinking of doing a 2.4L stroker built then possibly a larger turbo would make sense in this case since the larger displacement would help the spool up as well..thoughts?
Old Nov 14, 2004 | 12:15 PM
MattGold's Avatar
yes.
-M
Old Nov 14, 2004 | 02:26 PM
Ted B's Avatar
Even with stock internals + HKS cams, a larger turbo can make much more power than the factory unit, even at boost levels that can be supported by 94 octane. The primary reason why is simply because a larger turbo will run more efficiently than the factory unit at higher air flow ranges, especially at higher rpm where the factory unit runs out of steam.
Old Nov 17, 2004 | 12:42 AM
Ang Wen Yan's Avatar
Get Quantam Stage 3++head with HKS 272/272 cams with gear and RNR 2.4 engine
1mad evo
Apr 24, 2007 03:53 PM
David Buschur
162
Jan 16, 2007 07:13 PM
_EVOlved_
Jan 14, 2007 07:32 PM
BadazzCR
97
Nov 14, 2005 11:59 AM
rt turbo
Apr 25, 2004 07:58 AM
