Cyber Evo
Old Nov 28, 2004 | 02:22 PM
Yaroslav's Avatar
Question Cyber Evo
http://www6.plala.or.jp/cyberevo/democar/index.html
Help to translate this site!
Old Nov 28, 2004 | 02:24 PM
Az3ar's Avatar
It says:
I am very fast and you are going to see my tail lights... They are talking about it on some other post. search for it.
Old Nov 28, 2004 | 03:32 PM
Yaroslav's Avatar
PLEASE translate me these links!!!!!!
http://www.garagehrs.com/demo-car/cy...-evo7-2003.htm
http://www6.plala.or.jp/cyberevo/democar/cp9a.html
Old Nov 28, 2004 | 03:39 PM
Yaroslav's Avatar
https://www.evolutionm.net/forums/sh...3&goto=newpost
this too
Old Nov 28, 2004 | 05:08 PM
WhosEVO's Avatar
Originally Posted by Yaroslav
here you go.....>>>>
A text to translate here Base vehicles The CT9A Mitsubishi run sir evolution VII RS engine a JUN 2.2L kit and forge piston & -- H section contest rod full counter crankshaft and 272-degree cam shaft -- JUN rushes killer HKS slide cam sprocket Apex'i RX6TCW76P 25 turbine Apex'i water-cooled waist gate power enterprise strengthening timing belt power enterprise heavy metal GASUKETTOKA station Marchais Diameter pulley burner processing of large dynamic balance balancer SHAFUTORESU 吸排気/ignition The Sun car / yeast KURAUDO One-off muff RASAN car Really [ one-off air INTEKU CyberEvo turbine outlet ] The front pipe CyberEvo The 等長 EKIMANI CyberEvo big serge tank HPI air cleaner Apex'i one-off interchange air conditioner The other types-of-a-car appropriation big throttle NGK (GT-R core) iridium plug HKS twin PAWASAN car hot WAIYASAN car Hot ground Fuel system () BOSCH strengthening fuel pump [ 282 L/h ] external collector tank power enterprise strengthening fuel pump (inside of a 255 L/h pure tank) Power enterprise 1000 cc in JIEKUTAZENITANI Collector tank Apex'i 燃圧 regulator ECU HKS FconV-PRO CyberEvo special Cooling system The HPI oil air conditioner RALLIART low TEMPU thermostat ARC RAJIETA remover tank east name OIRUSAMO KIRAPAWA enterprise three layer RAJIETA of 3 plastic IRAJIETA hose Apex'i aluminum axle part TEIN vehicle high-pitch -- kit CyberEvo special CyberEvo wide tread ROWAAMU CyberEvo long drive shaft AP engineering FURUPIRO CUSCO front SUTABI bracket Tire ADVAN A048 (S) 255/40-17 Please input.
It is a wheel here. VOLKRACING CE28Fr:9.5J-17+15Rr:9.5J-17+35 brake Power craft OX brake pad CyberEvo special garage HRS original GT rotor (front) AP engineering Stainless steel mesh brake hose Drive system A front / center LSD:CUSCO MZ TYPE-RS rear LSD:CUSCO MZ-RS Ogura Clutch The twin plate clutch garage HRS carbon driveshaft CyberEvo automatic call distribution controller The Tarzan 山田 special oil and fats engine: -- Oberon missions transfer: -- Oberon F808S rear LSD: -- Oberon 85W-140 brake Froude: -- Oberon power-steering: -- OBERONOIRU filter: -- power enterprise MAGUPAWA 2 body reinforcement AP engineering full body reinforcement AP engineering Roll cage 電装 system The CyberEvo automatic call distribution meter NEKO An A/F640 Apex'i water thermometer and 油温計 TRUST The BUSUTO meter TRUST Profec BHKS 燃圧計 Sun car Hot INAZUMASAN car Power view HID coating C-WEST a full EARO front bumper and side step rear bumper carbon bonnet carbon suitcase carbon -- GT wing garage HRS front wide fender garage HRS special lightweight door mirror garage HRS One-off single WAIPASAN car Black face light cruise FRP door (passenger seat) Car station Marchais FRP door (rear) VOLTEX carbon under-par NERUAKURIRU window (except a front) BLISS Body coating Interior RECARO SP-G TAKATA Four-point formula seat belt KEYS steering garage HRS one-off lightweight dash Baudelaire Bulk head partition board OKUYAMA Aluminum battery box Please input a text to translate.
hope this help
ak47po
Dec 22, 2007 08:51 AM
A73 Lancer
Lancer Aftermarket Forced Induction Tech
13
Feb 21, 2004 09:40 PM
