need help please!!!!!
Old Dec 1, 2004 | 11:59 PM
03Evo8girl's Avatar
Unhappy need help please!!!!!
i just installed a greddy type-s bov on my evo and i'm having some problems. just as it gets to 3000rpm it starts making a weird high pitched whistling noise. it's hard to describe. i don't think it's normal b/c all my friends that have it don't sound like that. hope someone can help me out with this or if i have a leak of some sort. thanks
Old Dec 2, 2004 | 12:11 AM
Jakeg97's Avatar
sorry cant help much cause i dont have one, but is the bov installed correctly and not backwards?
Old Dec 2, 2004 | 12:12 AM
Jakeg97's Avatar
maybe this will help
https://www.evolutionm.net/forums/sh...problem+greddy
Old Dec 2, 2004 | 12:17 AM
Jakeg97's Avatar
try a search
Old Dec 2, 2004 | 12:19 AM
Jakeg97's Avatar
https://www.evolutionm.net/forums/sh...install+greddy
Old Dec 2, 2004 | 03:13 AM
TomeiEvo's Avatar
You've probably plumbed the vacuum signal hose on the bottom plug fitting instead of the top one which blows it open as soon there is a positive pressure. Look to see if you've got the fitting on the top, not at the bottom.
Old Dec 2, 2004 | 07:08 AM
03Evo8girl's Avatar
i don't have a problem with idling and the vacuum hose is on the one that is perpendicular to the bov, not the one that comes off it diagonally. i basically help it up to the stock one and but the hoses on the openings that matched...is that correct or should i have hooked it up the other way around?
Old Dec 2, 2004 | 07:10 AM
TampaTurbo's Avatar
yes try to make sure its not installed backwards. I hear of this many times with the Greddy Type S.
Old Dec 2, 2004 | 07:16 AM
03Evo8girl's Avatar
is it supposed to sit vertical or horizontal???
Old Dec 2, 2004 | 07:26 AM
evo 8 ya's Avatar
The flanged part goes to the hose connected to the Upper i/c piping.
Old Dec 2, 2004 | 07:29 AM
03Evo8girl's Avatar
does anyone have a picture of one installed?
Old Dec 2, 2004 | 07:40 AM
evo 8 ya's Avatar
yea give me a sec.
Old Dec 2, 2004 | 07:54 AM
evo 8 ya's Avatar
the batteries in my camera are dead and I'm at work. Check this link 10th post down
https://www.evolutionm.net/forums/sh...ad.php?t=93621
Old Dec 2, 2004 | 08:06 AM
03Evo8girl's Avatar
ok so the purple is not supposed to pointed on top. that is kinda how mine looks except for the vacuum hose for mine is in a different spot...you have to look behind the bov to see it. whereas that one looks like it goes around to the front
Old Dec 2, 2004 | 08:32 AM
evo 8 ya's Avatar
Yea I unbolted the top of the BOV and turned it so it wouldn't hit the upper rad hose. It dosn't matter as long as the vac line isn't getting pinched.
