Evo Oil Filter Question
Old Dec 9, 2004 | 03:21 PM
GOKOU's Avatar
Originally Posted by 90GSX-03EVO
What???
Do you also agree that since water is cheaper, we should use that instead of motor oil?
OEM doesn't always mean best. You get what you pay for, and Mobil 1 has been known for years as being one of the best out there for a very competitive price.
BTW, I was showing the price the dealership would charge for the OEM oil filter. If you are going to compare the price Auto Zone will charge for the Mobil 1 one, then I can quote the dealership's price.
Don't put words in mouth cuz I never said that OEM is better or cheaper is better. Everyone have their own opinoin and decision as to what they use. I choose to stick with OEM because it's cheaper and is use by . Although FRAM is not the best I've been using it on supras, hondas for the life of the car and have seen no issues. To each their own peference.
Old Dec 9, 2004 | 07:56 PM
rsboy's Avatar
Check out Purolator also. They are priced very nicely and have been good for me when I had my Impreza. I will most likely buy them for my next oil changes. Good quality filters.
Old Dec 9, 2004 | 08:26 PM
90GSX-03EVO's Avatar
I just don't understand why people would cut corners on something as important as an oil filter. These engines have very tight tollerances, and I want something that I know will do a good job of filtering out any crap ASAP.
HREVO: Yes, you need to use a new crush washer every time you take out the oil drain plug.
4ce fed: Buy an OEM filter and a Mobil 1 filter. Take a Dremel tool and cut them both open. Maybe you were lucky, maybe the damage will take longer than 2 years (probably will start showing up just after the cars start falling out of warranty age, if you get what I am saying), or maybe the filter worked on that car, and not the Evo. There are quite a bit of differences between the Evo 1,2,3/DSM 4G63 and the Evo 4,5,6,7,8 4G63. For one, I don't remember either of my Eclipse GSX's saying anything about having to use synthetic oil......
Old Dec 10, 2004 | 04:05 AM
4ce fed's Avatar
I'm glad you don't like the OEM filter. Less demand means lower prices for me. I never said it was the best.
However, I did AutoX in my Eclipse many times. Put many miles on it. Sure there are differences between the DSMs and the Evo. But the oil flows through the filter the same way. And anyone who knows anything about marketing and warranties would know that synthetic isn't required for our cars. The Evo would probably run just as long on dino oil. Syn oil helps protect the turbo from those morons that like to go 90mph to work and then shut the car off without any cool-down time. They make more $$ on oil changes due to higher prices of oil, and pay less in warranty claims.
Same for FRAM. People always said they were complete garbage. I used FRAM on my first Eclipse for close to 3 years. Zero problems. Now, did the internals of my engine look as good as one that ran a Mobil-1 filter? Who knows. The point is that the OEM filter, and most filters out there, are good enough for 95% of the people. If you plan on track racing, where there is a huge demand on the car and oil system, then yes, a different filter might be a good idea.
Oh, and I use the same crush washer every time I change my oil. No leaks.
Old Dec 10, 2004 | 06:47 AM
GOKOU's Avatar
Like I said to everyone their own choice. And if you want to dep dive I think there are far more things to be concern about compare to oil filter. If you can show me data that a car which uses mobil 1 oil filter vs fram or OEM last longer by xxxx mileage then that would be great. As far as my experience go I've never had issue using OEM and $5 oil filter vs $10 oil filter.
I've never use a new crush washer either.
Old Oct 3, 2007 | 03:26 PM
JJsEvo8's Avatar
WIll using a non OEM filter void your warranty?
Old Oct 3, 2007 | 03:29 PM
kreionic's Avatar
Damn man brought back a thread from almost 3 years ago
Old Oct 3, 2007 | 03:56 PM
wokuku's Avatar
Sure beats starting a new thread and then been called out to search lol
Old Oct 3, 2007 | 04:03 PM
kreionic's Avatar
Very true.
Technically I can guess it could void a warranty. Mitsu is not the greatest for warranty stuff anyway. If your worried about keeping yours stay oem
Old Oct 4, 2007 | 04:17 AM
Yeah, I would have hated to turn you into #23.
Old Oct 4, 2007 | 07:56 AM
JJsEvo8's Avatar
One other quick question along the same lines.
Does mitsu track your oil changes with them? ie if i get the oil changed by someone else would that get me into warranty trouble?
I can get the OEM filter for 6 bucks and some Mobil1/Amsoil for dirt cheap. A lot better price than the $80 oil change the dealer wants to charge!!!
Old Oct 4, 2007 | 09:39 AM
wshihdnevo's Avatar
I always used mobil 1 filters until i found out oem was much cheaper, so i go w/ oem...I think its prob around the same quality for the price. IMHO
EDIT: I now run Wix and might be possibly trying Baldwin filters too.
Old Oct 4, 2007 | 11:32 AM
Just keep your reciepts for everything. Also, since you're doing your own maintenance, make sure you continue to lube everything else on the car (CV joints come to mind). Most people don't and then they wonder why they start clicking after about 60,000 miles.
Old Oct 9, 2007 | 01:05 PM
JJsEvo8's Avatar
Ok, so i took my car into the dealership and watched em/talked with them during the oil change..... All the joints on the car are sealed... so there isnt any other part to lube!!!! They did take the charge down to 60 bucks instead of 80 because i was cool with the tech.
As long as I use Mitsu filters/synthi oil and have a reciept they wont mess with the warranty.
Oh, and they are replacing the rear wing for free (under warranty) since its sun damaged...
Old Oct 9, 2007 | 02:06 PM
Karash's Avatar
When mitsubishi switched to a universial filter, it was crap. In 2K3, Mitsu had a filter specifically for the Evo, and then stopped offering that a year or two later.
Never buy or use the OEM filter, seriously...especially if you use race gas at all.
I use a K&N model 1010 and it works great. The last OEM filter I had on my car got internal damage somehow and was 'fluttering' inside. I thought it was engine knock, but it turned out to be the OEM filter.
