Evo Oil Filter Question
Old Mar 1, 2010 | 03:22 PM
  #31
chinoxmk22's Avatar
A filter is a filter.
Old Mar 1, 2010 | 08:03 PM
  #32
dambikeracer's Avatar
Top three filters based on oil test:
1: Amsoil
2: Royal Purple
3: Wix
Old Mar 1, 2010 | 08:06 PM
  #33
If your saying that all filters are the same... YOu are wrong! A filter is not just a filter. If you think that is true, you should go by a fram filter and run the cheapest oil you could find. If a filter is just a filter, then all oils must be the same too.
Old Mar 1, 2010 | 08:26 PM
  #34
iTune's Avatar
K&N HP1010 son...... Don't run anything else if you care about how your oil is filtered.
Old Mar 1, 2010 | 08:32 PM
  #35
redhott92's Avatar
as long as it filters the oil... then it will all work well
Old Mar 2, 2010 | 04:44 PM
  #36
apagan01's Avatar
sorry negative !
paper is not the same as syntheti cloth,,, so a paper filter is not the same as synthetic media
Old Mar 2, 2010 | 06:42 PM
  #37
iTune's Avatar
Originally Posted by apagan01
sorry negative !
^^^^^that.
Old Mar 5, 2010 | 10:05 AM
  #38
apagan01's Avatar
Originally Posted by 90GSX-03EVO
Go buy a OEM filter and a Mobil 1 M1-108 and cut them open. See if you laugh at what you find.
Used OEM for long time on my IX,,, eventually i decided to cut one open to see how my engine was doing and to my suprise i find garbage paper element filter,,, you gota be kidding me,,, i want the best in my car Synthetic media not freaking paper
Old Mar 5, 2010 | 12:10 PM
  #39
jestoy7's Avatar
Wow, I swore by OEM but I've never really cut one up to compare. I take it that the ones that you offer are synthetic media. Is the oil filter part number different for a DSM to an Evo? I'd like to try one on my GSX if you carry it.
Old Mar 5, 2010 | 02:14 PM
  #40
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Holy necro bump, wtf?
Old Mar 5, 2010 | 06:23 PM
  #41
apagan01's Avatar
i do have GSX filters.
pm sent
Old Mar 6, 2010 | 06:58 AM
  #42
barneyb's Avatar
sorry negative !
What is the difference between paper and synthetic media? Well, I know the name is different. What is the filtering difference? What does synthetic media provide that paper cannot?
Old Mar 6, 2010 | 05:17 PM
  #43
apagan01's Avatar
synthetic media can filter down to 12 microns <<< that makes my day right there
Old Mar 7, 2010 | 06:56 AM
  #44
barneyb's Avatar
Paper does not occur in nature. So, if you wish to use the word synthetic in the way it is used to describe synthetic oil, then paper is synthetic. However, synthetic, in regards to an oil filter element, is a word used by the advertising department in an effort to convey the fact that the filter maker has done something to the filter element that makes it something other than a normal paper element.
That something may be no more than the addition of cotton fibers to the paper. Or it could mean they punched holes in the paper. It could mean that the paper is made of something other than wood fibers. It could mean the element is multi-layered, sometimes with progressively smaller holes in the inner layers. And, I suppose there are other treatments and creations I haven't remembered or imagined.
The Purolator Pure One filter has been, and most likely still is, the best filtration element available. But, because the pores in the element are so small the oil volume that can be moved through the element is reduced. So, the maker packs in the can a huge amount of media to increase the surface area of the element. Still, some people avoid using this filter because they worry about oil delivery or the bypass valve opening. The point is, there is more to making an oil filter than having the best filtration.
Also, if the maker uses a very small pore size then these pores are more subject to plugging. A plugged filter that bypasses means you have no filter at all. The progressive multilayered filters are an effort to address filter plugging.
Old Mar 7, 2010 | 07:10 AM
  #45
erald01's Avatar
i have been using mobil one oil and mobil one filter on all my previous 5 sports car since 1999 and it yet has to fail me.
