Torque Question
Old Dec 17, 2001 | 01:57 PM
LeeLegend's Avatar
thanks guys this is all good stuff, i am using Shell Optimax all of the time, i am going to do the pump and regulator, and have a look into the controllers i fancy the blitz but will have another look at the apexi
lee
Old Dec 23, 2001 | 07:59 AM
mouton's Avatar
the reason the sort ecu runs rich at the top is because it has a lot of ignition retard after 6k
this is also why the boost drops away at this point also
Old Jan 10, 2002 | 04:44 AM
LeeLegend's Avatar
right update on this thread...
blitz going in on Tuesday, and also a fuel pump, what is everyone opinion on a fuel regulator?
lee
Old Jan 10, 2002 | 05:20 AM
mouton's Avatar
pump and reg go hand in hand
you need both !
Old Jan 10, 2002 | 05:25 AM
LeeLegend's Avatar
i thought you did one to up the fuel flowrate and the other to up the pressure...
did you do both with your sports ecu?
lee
Old Jan 10, 2002 | 02:14 PM
Michaelk's Avatar
You see, that is the question. I would think the standard car will have some sort of a fuel regulation system, probably deciding how much energy is needed for a given fuel pressure, or am I wrong??
Old Jan 21, 2002 | 06:36 PM
LeeLegend's Avatar
fitted the controller and fuel pump, well pleased....
car seems smoother on boost, no spikes or jumping about.
spoke to alan at dragon about the pump/regulator, he reckons neither are a must at this level but the pump is nice as it lets more fuel be available if it is needed.....only problem is you can hear it hum a bit when sitting on idle.
regulator is only needed if you go the apexi route of leaning it out to avoid the fuel cut, their 400bhp demo car has not had this done, so sort of proves a point.
lee
Rom
Dec 23, 2015 10:27 AM
Vivid Racing
EvoX 'For Sale' Engine Internals and Drivetrain
60
Jan 21, 2014 04:52 PM
Ktmshorty
Dec 15, 2013 10:53 AM
MO_EVO8
43
Mar 27, 2005 07:44 PM
