Can't get boost under 30psi after turbo kit..
Old Dec 11, 2004 | 08:22 PM
DSMotorsport's Avatar
Guys...it's a pressure SIGNAL. the size of the hose does not make one iota of differance, as there is no flow in the wastegate system. the hose should be 4mm internal dia, but it would work just the same with a 1mm internal dia or a 30mm dia.
don't worry about it, and don't waste your time change vac hoses and taking the signal source from other places. the bov line is fine, probobly ideal even.
it's probobly just a sticky gate and needs to be moved a few times...burr on the shaft or something.
Old Dec 11, 2004 | 08:24 PM
Originally Posted by Spec C
Ya really think the Ic pipe is thick enough to tap? i am definetly not drilling my turbo, i have drilled and tapped plenty of times, but i am not comfortable enough to do the turbo..
Dave-
I drilled and tapped the lower half of the ic pipe between FMIC and throttle body for the AEM ait sensor. FYI it's thick enough to tap and get a few threads. but don't bother, that's not the problem.
Llew
Feb 6, 2017 07:10 AM
EvoDan2004
28
Oct 25, 2013 07:58 PM
94AWDcoupe
23
Feb 2, 2009 10:50 AM
StevenStarke
15
Dec 3, 2008 12:28 PM
rraulston
10
Jul 27, 2005 07:19 AM
