Tranny Fluid or Oil leaking on DP??
Old Dec 13, 2004 | 06:50 AM
YEVOVIII's Avatar
I went to a dyno day this Sat to get my cams adjusted by a few friends and also add a antifouler to my test pipe. When we jacked up the car, i noticed that there was staining on my DP and all over the flexpipe. When the car get hot you can smell a sweet buring smell. Not ver strong and you can only smell it when you get underneth the car. I just had my clutch replaced and all the fluids changed a couple of weeks ago. I have checked my oil and trnny fluid and all seems well. Im just kinda scared because it looks like whatever is dripping is still slowly dripping. Any ideas guys?
Tony
Old Dec 13, 2004 | 08:52 AM
YEVOVIII's Avatar
anyone
Old Dec 13, 2004 | 09:44 AM
oguratevo's Avatar
Is there any oil drip marks from where you parked your evo? if not, its probably its some oil drips left after you have TC oil drained, same thing happened on my '03 Evo but it went away. Just check it from time to time.
Old Dec 14, 2004 | 01:18 AM
Fourdoor's Avatar
I had this exact problem and it turned out my transfer case fill plug wasn't tight. It is pretty much directly over the downpipe. Tighten that puppy up and you should be fine
Keith
Old Dec 14, 2004 | 10:02 AM
Jamie@WORKS's Avatar
Check to make sure the axles have been completely snapped back into place.
Jovan Caro
May 25, 2017 09:24 AM
BillCosbysPudding
Mitsubishi TC-SST Discussion
73
May 11, 2017 09:12 AM
Big Bald
Jan 3, 2014 04:54 PM
hanis213
20
Jul 19, 2010 01:19 PM
EvilBlueEvo8
Aug 12, 2004 07:43 PM
