Need a real answer on transmision oil
Old Dec 27, 2004 | 05:30 PM
  #46
erikgj's Avatar
Originally Posted by johny719
wait before i go out to try MT-90 or BG synchroshift... are there any additives in either of those 2 that are bad for our tranny? I think earlier in this thread, someone said that Redline MT-90 is bad for our brass...
Just don't use a GL-5 rated product in the transmisson.
Old Dec 29, 2004 | 04:22 PM
  #47
erikgj's Avatar
I've tried both Redline and BG in Evos. I would go for BG Syncroshift. The Redline had a notchiness when cold that BG just does not have. When warmed up it is even better.
Old Dec 29, 2004 | 05:41 PM
  #48
GEARS's Avatar
The 5 speed transmissions in the EVO 4-8 tend to shift best with a GL-4 gear oil that meets specification for synchromesh. Like several have stated here and there on this forum, do not use a GL-5 in the transmission. I would avoid using any gear oil that claims to be GL-3, 4 & 5 spec. Instead, option only for a GL-4 oil that meets.....specification for synchromesh. These oils will improve the effectiveness of the synchronizers and that means a better shifting transmission.
GL-5 oils should not be used in the Mitsubishi transmission because they are too slippery and reduce the effectiveness of the synchronizer and you don't want that because the synchros basically act like brakes, their job is to bring the speed of the various transmission components up to the same “synchronized” speed with one another so the engagement teeth mesh at the same speed and don't get all torn up.
When it comes to the 6 speed Mitsubishi specifies the Diaqueen Super Multi Gear Oil, part #MZ313376. Could you use a different oil in this transmission? Most likely you could but consider this, Mitsubishi rarely uses the phase "exact equivalent" and when they state to use the Diaqueen SMGO or the "exact equivalent" it's probably best to follow the advice.
Now I'm going to hijack this thread for a moment.
In the transfer case and rear differential you must use a GL-5 "Hypoid" type gear oil. The transfer case features hypoid gears to transmit that power to the drive shaft. The word hypoid is short for hyperboloid which refers to the design of these gears. All you need to know is that hypoid gears; don’t share a common axis, run quiet (for the most part) and they are a strong design. Yet by design the gear teeth must slide across one another during their meshing and this is why you must us a GL-5 Hypoid type gear oil in the transfer case and rear end, you need that slippery oil here. Use the wrong oil and the transfer case will start howling and growling within a couple tanks of gas. Mitsubishi specifies the Diaqueen LSD Gear Oil in the transfer case and rear end of the EVOs. This oil is a single viscosity, 90 weight, and the part number is #377610. If you can’t find this oil you must find a gear oil that meets the GL-5 Hypoid specification. Again this oil must ONLY meet GL-5 preferably 90 weight. Do not use a gear oil that claims to be GL-3, 4 & 5. These one size fits all type oils are not recommended anymore than a one heat range fits all spark plug. Lastly, multi viscosity index modifiers and dyes both reduce the film strength of the oil; they take up valuable parking spaces on the molecular level reducing film strength and that’s what the transfer case and rear end both need.
Thanks for the space,
Jon@TRE
www.teamrip.com
Old Dec 29, 2004 | 05:47 PM
  #49
kapolani's Avatar
Jon@TRE
www.teamrip.com
Thanks for that post... Very informative..
I've been researching this myself and haven't found answers till now.
Old Dec 29, 2004 | 06:03 PM
  #50
marksae's Avatar
Excellent write-up Jon@TRE! Very good info!
Old Dec 30, 2004 | 07:29 AM
  #51
upstateEVO's Avatar
Jon@TRE
www.teamrip.com
Is there a specific brand transmission fluid you use/ recommend for the Evo 5 speed?
Thanks for the info!
Matt
Old Dec 30, 2004 | 11:44 AM
  #52
johny719's Avatar
thanks
Old Dec 30, 2004 | 12:10 PM
  #53
NoTiGuY's Avatar
Dudes,
very informative.... what about MOTUL products?
Old Jan 2, 2005 | 05:05 PM
  #54
GEARS's Avatar
Just be concerned with the oil meeting the specification that is in your owners manual, this is way more important than the brand name.
Have you guys tried 3rd gear power slides in a big parking lot yet? I love this car
Old Jan 2, 2005 | 05:10 PM
  #55
GEARS's Avatar
and yes, Motul is a good oi. Just make sure it meets Mitsubishi's specifications that are in the owners manual.
Old Jan 2, 2005 | 05:30 PM
  #56
oguratevo's Avatar
I used BG synchroshift (GL-4 rating) on the transmission and Redline Shockproof on the transfer case/rear diff. (GL-5 rating), period.
Old Jan 2, 2005 | 05:41 PM
  #57
two2thehead's Avatar
Try taking it out in nice smooth dirt and get the damn thing to spin in a little tight circle till you puke...don't try it in gravel, rocks will pile up on the outside rear rim and chip it up bad. A friend did it in his STI, very sad.
Old Jan 2, 2005 | 05:52 PM
  #58
GEARS's Avatar
Thumbs up
Taking the dirt road home will just have to wait till I'm bored with her.
Until then, I'm visiting parking lots late at night and scribbling the AWD signature all over them
Old Jan 13, 2005 | 01:56 PM
  #59
NoTiGuY's Avatar
i cant seem to find a SAE90 gear oil for my transfer case. Would it be alright if i were to use Motul Gearbox 80W-90 or Motul Motylgear 75W-90 or 80W-140 for both my rear axle and transfer case? These oil are semi synthetic based....
Old Mar 24, 2005 | 08:19 PM
  #60
wannaevo's Avatar
Where to buy BG synchroshift or Gm synchromesh for the trans.
