Mirage engine swap to 4g63
Old Dec 22, 2004 | 02:18 PM
ralliartlanevov's Avatar
i was wondering if any one in this forum did a mirage engine swap. i planning to get a mirage and do a 4wd engine swap to the mirage. i know u have to vut the body panels, but i was wondering if it is possible to do it. i really like the evo v and i will like to do this project.
Old Dec 22, 2004 | 02:22 PM
tokeone's Avatar
i know there are plenty of sites on the swap for 89 mirages, but i dont think i know any on awd. just fwd
Old Dec 22, 2004 | 02:29 PM
Talking
can u give me some reference. i was planning on doin it to the 97-2001 mirage. i neva saw anyone do it so i have to do that y.lol
Old Dec 22, 2004 | 05:52 PM
MalibuJack's Avatar
This is a project I've been planning.. 2 door 2001 Mirage DE.. Still trying to find a good donor car.. the bad news is its EXPENSIVE since you need an entire drivetrain, which means you need a donor evo to get everything INCLUDING the wiring harness.. Once you have everything you need, swapping it over is fairly straightforward, but you will likely have to cut a good sized section out of the trunk pan and make a little room for other parts.
There's quite a bit of welding involved, and you will not get the rigidity of the evo chassis by any means... which means you may need to run a 4 or 6 point rollbar to stiffen the chassis.
I am currently doing this on a 93 Honda Civic Hatchback, and the types of modifications is no different, but unless you get everything you need, piecing it together over time is just going to end up being very expensive and frustrating. (I know, this first conversion is turning out to be a huge PITA)
Old Dec 22, 2004 | 06:19 PM
Speedlimit's Avatar
Admin Emeritus
Some of the local Philly guys might know if Nate Pharr completed the swap. I know he was planning on putting a 4G63 in his Mirage, although not sure if he wanted AWD. He didn't mention any major hurdles to completing it and I know he has the knowledge and experience to pull it off. (Drives the maroon VR4 Gallant that runs mid 11's).
Speedlimit.....
Old Dec 22, 2004 | 06:38 PM
WildRice's Avatar
What about using some AWD Tallon or Eclipse parts?
Old Dec 22, 2004 | 06:44 PM
RogueSTi's Avatar
Gee. Nobody's ever asked this question before...Hmmm...
I typed in "mirage engine swap" in the search bar and got 70 results...here are the top few:
https://www.evolutionm.net/forums/showthread.php?t=107516
https://www.evolutionm.net/forums/showthread.php?t=101956
https://www.evolutionm.net/forums/showthread.php?t=38515
https://www.evolutionm.net/forums/showthread.php?t=10128
https://www.evolutionm.net/forums/showthread.php?t=87967
Old Dec 22, 2004 | 06:51 PM
sleek_concepts's Avatar
we are curently planning to attempt this swap in a 93 mirage. not awd just fwd but it should still be fun. we are also converting a mx3 to rwd with a 13b, that will be fun also.
Old Dec 23, 2004 | 11:49 AM
AdamJ39's Avatar
You can all check out my car its a 2000 2 Door Mirage...its running FWD right now and i'm about to place the AWD in here in the next month...still waiting for a new fuel tank and to recieve my new wheels...honesltly for all you who are planning this swap...hope you have lots of funds and are planning of doing it yourself personally becuase its very inclusive and i'd gather that a shop would rip someone apart if asked to do it...also most shops would refuse to mess with the rear assembly for the sole factor that the car can become ruined if installed improperly... anyway i'm got nearly all the details about this swap but at this time i wont be sharing any untill i'm finnished...heres a few pics for those of you that havnt seen i'm sure...
if anyone wants to see anything else they can go to my pages....
http://AdamJ39.onlineshowoff.com
or
http://www.cardomain.com/id/adamj39
-Adam
Old Dec 23, 2004 | 03:14 PM
94AWDcoupe's Avatar
Adam, great to see someone tackle that project. I had all the parts do make a 97 AWD a few months ago. but decided to sell the parts for profit cause it wouldn't out perform my 94 AWD coupe. The 93-96 coupes are 150 lbs lighter than the 97-2000 coupes. I think the early cars are prettier too, but that is just me. I built the 94 three years ago. The best time so far is high tens at 129 on 93 octane. That is with a VPC/GCC setup. The aem is set to go on the car in january. car weighs 2525 with full interior and a/c.
It looks like you didin't move the engine back. You dont have room for large frame turbos. I set the engine back almost 1 inch. The axles are not straight but is not a problem, its not enough stress on the joints.
Your going to love the car. Way funner than dsm cars and evo8s.
Old Dec 23, 2004 | 10:02 PM
AdamJ39's Avatar
i'm only looking to do a 20gtd06 right now honestly....if i grab 350-400 that will allready be more than i ever imagined to get outa this car....but if i do go for somethign larger, i'll do a sedan front end conversion WAAAAY before i ever moving the engine back...i dont like the sound of that aT all
-Adam
Old Dec 24, 2004 | 07:12 AM
94AWDcoupe's Avatar
-Adam
First a sedan front would look stupid on a 2d car. Not to menstion it would be ten times more work than moving the engine back an inch. You dont like the sound of the axles being offset an inch? The rear axles are the ones that take far more stress than the front. On a hard launch my rear axles are offset almost four inches. I have never broke an axle. And my car is 200hp more than your your 400hp plans. Just trying to be helpfull but obviously you don't need it.
Old Dec 24, 2004 | 02:22 PM
AdamJ39's Avatar
dont know what got you all pissy but i wasnt intendent that it was a dumb idea...or tring to bash anything i was just saying...i would just rather create more space then push things around...anyway...no need to get in a bind...just two different feelings on one subject...no big deal...sorry
-Adam
Old Dec 24, 2004 | 02:28 PM
AdamJ39's Avatar
I wanted to ask you if your not sour...what if any reinforcement you did to the rear end assembly in reguards to the frame rails...i know the 4th gen set up caters a fair ammount more to AWD then in a 5th gen but still did you just place any reinforments or anything or just run the factory rails and mounts...i allready have a idea as to what i'm going to do on mine but i'm just curious as to what worked sucesfully on yours...
-Adam
Old Dec 24, 2004 | 02:30 PM
bbuevo's Avatar
Thumbs up AWD Mirage swap!
The following site will hook you up...
www.vysor.com/lancerproject
