Mirage engine swap to 4g63
Old Dec 25, 2004 | 12:13 AM
94AWDcoupe's Avatar
I used the existing trailing arms. I welded in bearing housings from dsm awd arms. I then completely fabricated a frame to support the rear end. My goal was to keep it light as possible. I used the stock tank and mounted it behind the axle line. My framework is likely stiffer than a factory gsr. If I had to do it again I would buy a rear clip from evo1-3 no matter what the cost.
For wht you are doing, using evo8 parts instead of dsm parts, you should use the evo8 rear parts. they are very easy to adapt to fit comparred to how I did mine. You have to use the evo8 pumpkin anyway so that is the smartest rought.
Old Dec 25, 2004 | 07:31 AM
AdamJ39's Avatar
i've got all evo4 parts right now including AYC which i'd like to rid myself of...including control arms....the mirage frame ralls look as though they are ready to accept the cradle assembly...and all the arms should mount up...what i was going to do was cut out 2 portions of the rails and give them the proper mounting for the cradle....the only mouints i'd be missing are the center pan mount and the furthest most aft mounts located again in the frame rails...I allready have new brakes/suspension etc etc...all i'll need is a new fuel tank and custom driveshaft...but i think i'm just gonna grab an evo4-6 tank which i'm hopping bolts up directly....but i wont know untill i get it here...
-Adam
Old Dec 30, 2004 | 10:27 PM
VTECH8TR's Avatar
Adam,
Awesome car and work .
Old Apr 18, 2006 | 07:47 PM
Migsubishi's Avatar
I'd like to here a little more about the swap into the Honda
Old Apr 18, 2006 | 08:06 PM
alloyic_rs's Avatar
Then go to a honda forum and ask around, not here.
Old Apr 19, 2006 | 07:25 AM
hybrids14's Avatar
Well, I got an AWD mirage hatchback EVO6/7 motor... EVO3 front end... a lot of work... pics at below hyperlink. If you have questions... you can ask me here
https://www.evolutionm.net/forums/sh...ght=56k+beware
Originally Posted by ralliartlanevov
i was wondering if any one in this forum did a mirage engine swap. i planning to get a mirage and do a 4wd engine swap to the mirage. i know u have to vut the body panels, but i was wondering if it is possible to do it. i really like the evo v and i will like to do this project.
Teal2nnr
Feb 21, 2016 08:31 AM
redcentinela
Dec 15, 2014 08:01 PM
EVOoctain845
Dec 15, 2011 11:06 PM
joberk3
Lancer-Mirage Compatibility Forum
61
Oct 12, 2009 11:34 AM
DN
Jul 7, 2004 01:27 AM
