Another clutch question
Old Dec 23, 2004 | 11:51 AM
herbal77's Avatar
I have 5500 miles on my MR, and the last couple of days , when I start the car for the first time in the morning. When shifting, the car vibrates a little while catching the clutch.
This stops when the car warms up.
any ideas
Old Dec 23, 2004 | 02:48 PM
superz's Avatar
This sounds normal. It may be that the clutch chatters a bit when completely cold and when up to temperature it is fine. At times depending on the clutch disc material it is normal to have to warm things up a bit to get the full effect of the material. It's like when you have a set of race spec brake pads, you need a couple of laps to get them up to their optimum performance. Don't worry unless it gets much worse.
Old Dec 23, 2004 | 02:50 PM
justchil's Avatar
That's normal. I ALWAYS let my car heat up a bit before driving.
Old Dec 23, 2004 | 03:37 PM
Jakeg97's Avatar
normal - i am very gentle to my evo when she is cold
Old Dec 23, 2004 | 03:47 PM
AUSS1E's Avatar
me 2....I try not to boost until its good and warm.
Old Dec 23, 2004 | 03:59 PM
justchil's Avatar
Cold in Hawaii?
Old Dec 23, 2004 | 04:17 PM
ThEHiTMaN's Avatar
Yep.. MY 03 does it also. You can feel the clutch grabbing. Once it is warm it is fine.
Old Dec 23, 2004 | 05:56 PM
Ev0 1's Avatar
Try letting it warm up first and see if the problem still occurs.
Old Dec 23, 2004 | 06:13 PM
justchil's Avatar
It may still do it even when u let the car warm up IF it's extremly cold outside and the car has been sitting a while.
I usually punch the gas a little bit and let it slip to warm up the clutch then its all good
