Big Problems???
Old Dec 26, 2004 | 01:15 AM
BSREVOLUTION's Avatar
Big Problems???
i was driving my evo a couple hours ago. i floored it in third gear and let off a 6500rpm's. a few minutes later my car feels very sluggish and has no power, but builds full boost the same. i pull over to check for a loose hose or something dripping from my car, but nothing was found. when i shift gears there is now a loud back fire. my egt's went over 1600F before setting off my defi alarm. i then coasted to a buddies house to park the car for the night. the motor idles fine but teh back firing is very noticable. just to let everyone know that i have 22223 miles on the car and i havn't changed the plugs i about 15000. so are my plugs fouled? or is the internal damage? if anyone could help me out please call me asap. thanks justin 661-978-4898
Old Dec 26, 2004 | 01:31 AM
btw, i havn't taken the plugs out yet. its 130am and im going back to my buddies at dawn to find out what is wrong. im just very worried about my car.
Old Dec 26, 2004 | 06:20 AM
GTVEVO's Avatar
Yep check the plugs and see if you have any of them damaged. Doesn't sound good though. Could be several things.
Old Dec 26, 2004 | 06:30 AM
TURBODAWG's Avatar
1600 F is not too high. 900 C is about what you want to stay under. 900 C is 1652 F . My old DSM used to run about 800 C at highway cruising... Check the plugs first, I dont know why they would be bad, but that is a good place to start...
Good luck...
Brian
Old Dec 26, 2004 | 06:38 AM
evo_08's Avatar
if the back fire happens all the time u may have a burn piston
Old Dec 26, 2004 | 11:39 AM
i took the plugs out and they were very white. im going to post pics asap. i also noticed my exhaust gas is very cold. im going to check the compression right now. i hope its nothing to serious. i didn't think 20psi and 10.xx-11.3 afr would cause internal problems.
Old Dec 26, 2004 | 03:15 PM
GTVEVO's Avatar
Very white is lean. You should probably put a wide O2 back on your car after the air temp turned cold and do some testing. You could be maxing out injectors and or not have enough fuel supply. If the car still runs sluggish compression test would be good as you are already are doing. Good luck hope the test goes well.
Old Dec 26, 2004 | 03:30 PM
2003evolution's Avatar
What your mods?
Old Dec 26, 2004 | 06:11 PM
my mods are on my sig. i already have a wideband. injectors are running 70% max. after i did my compression test (which was 140 in all four) i noticed that my utec map switcher was set on map 4 instead of my tuned map 3. im thinking my gf kicked thw switch last night while we were driving. i disconnected the battery and reset the ecu. and now everything is peachy.
Old Dec 26, 2004 | 06:21 PM
is 140 to low for compression?
Old Dec 26, 2004 | 06:27 PM
GTVEVO's Avatar
Good deal, I hope that is what happened but don't know y it would backfire. Guess it could of gotten really rich due to the injectors and fuel pump. The compression test looks good but you should still get your AF ratio checked again if your plugs are white. Colder weather could of caused you to go a little bit lean in some spots. Just rather be safe than sorry.
Old Dec 26, 2004 | 06:49 PM
i think my ecu got all screwed up because the maps were changed while driving. im planning on retuning this week. thanks guys
Old Dec 26, 2004 | 07:10 PM
DynoFlash's Avatar
Glad to her it was the ole girlfriend kicking the map switch and not the piston exploding !
Old Dec 26, 2004 | 07:27 PM
you can say that again AL. Al do you think my compression is to low?
Old Dec 26, 2004 | 07:33 PM
Quickshift's Avatar
Your compression is fine man
