UR Test Pipe, 2.5" or 3 "??
Old Dec 29, 2004 | 09:22 AM
93civEJ1's Avatar
3" testpipe worked with my stock DP fine.
Old Dec 29, 2004 | 09:27 AM
mitsuorder's Avatar
you check the flanges much? mine had exhaust residue streaks everywhere. what did you use for gasket material between the two dissimilar diameter pipes???
Old Dec 29, 2004 | 09:31 AM
93civEJ1's Avatar
i used stock gaskets and it didnt seem to leak any, the only leak i ever had is when i bolted on a new DP, but thats because the gasket i used was messed up.
Old Dec 29, 2004 | 09:33 AM
4-BNGR's Avatar
Originally Posted by krafty
How does a 2.5" TP bolt up to a 3" cat back if the sizes are different?
The flanges are the same and will mate together (flange on catalytic to flange on 3" (or) no flanges if its a slip on).
2.5" dp
2.5" tp (or) hfc (or) stock cat
3" cat back
For "stock" turbo application. Get your 3" turbo back for turbo upgrade. That's my 2c.
Old Dec 29, 2004 | 11:57 AM
Jakeg97's Avatar
Im so confused now... what are the sizes of the stock down pipe and stock cat back?
2.5 inch for both
i have never tired running a larger size test pipe than stock system . but i dont think it will work as said above.
here is a link to a 2.5 inch test pipe that will replace your cat on your stock exhaust system
Old Dec 29, 2004 | 11:58 AM
Jakeg97's Avatar
oh yeah the link
http://www.ultimate-racing.com/Produ...Downpipe.shtml
Old Dec 29, 2004 | 12:00 PM
Jorge T's Avatar
Stock cat has a 2.45" inlet and a 2.33" outlet
Old Dec 29, 2004 | 12:35 PM
mitsuorder's Avatar
cool, thank you for the proper measurments Jorge T, I knew it was considerably smaller than the 3" outlet and looked very close to around 2.5", good to know the true sizes
Old Dec 31, 2004 | 07:06 AM
Z1 Performance's Avatar
For an otherwise stock exhaustk the 2.5 inch is the one to get
For any aftermarket exhaust, the 3 inch is the one to get
Will the 3 inch fit? Technically yes, but it is very prone to leaking due to the flange differences and lack of mating surface. Physically it blts up because the flanges are slotted
http://z1auto.com/prodmore.asp?model...ust&prodid=481
Adam
Old Dec 31, 2004 | 07:55 AM
omirix's Avatar
thanks for measurements, Jorge T
WhiteCtEvo
Nov 1, 2011 10:44 AM
switchblade906
15
Nov 17, 2008 08:36 AM
switchblade906
Oct 31, 2008 08:59 AM
jimntjames
Apr 20, 2005 12:45 PM
TRDHarrier
19
Oct 19, 2003 12:34 PM
