leaking transmission, help!
Old Dec 29, 2004 | 01:09 PM
cityhugo's Avatar
took a look under the car today, saw some oil leaking from the transmisson. the area that’s leaking is right on top of the front sway bar. not motor oil but a very thick oil almost like gel. anyone know what that is? can i still drive the car? any help? thanks
Old Dec 29, 2004 | 06:34 PM
cityhugo's Avatar
BTW, I have HKS Twin Plate
Old Dec 29, 2004 | 06:37 PM
Curt@MrLed's Avatar
Former Vendor
well its overfilled or your output seal or housing is leaking
Old Dec 30, 2004 | 09:34 AM
cityhugo's Avatar
took some pic of the leak, do anyone know what is broken? the seal? how much do u think is going to cost me? can i still drive the car? what needs to be replce, thanks all
Attached Thumbnails leaking transmission, help!-leak11.jpg   leaking transmission, help!-leak21.jpg   leaking transmission, help!-leak31.jpg   leaking transmission, help!-leak41.jpg   leaking transmission, help!-leak51.jpg
Old Dec 30, 2004 | 09:35 AM
cityhugo's Avatar
more
Attached Thumbnails leaking transmission, help!-leak61.jpg   leaking transmission, help!-leak71.jpg
Old Dec 30, 2004 | 10:29 AM
cityhugo's Avatar
come on, where is the guru when i really need them, haha
Old Dec 30, 2004 | 10:34 AM
IgotaWhiteOne's Avatar
it is probably an o ring that was left out...
Old Dec 30, 2004 | 10:39 AM
cityhugo's Avatar
But i did my clutch like 1/2 year ago and never a problem, why just now?
Old Dec 30, 2004 | 10:47 AM
FuelsResearch's Avatar
Looks like a seal for the cv shaft, if the leak is coming from where the shaft enters the housing. The fluid would be tranfercase fluid,( thick, smelly, like sulfur) because the open front diff is driving that shaft. There should be a dust seal and a fluid seal right there. Seal replacement might not be too costly, although I am not sure what it entails.
Old Dec 30, 2004 | 10:50 AM
cityhugo's Avatar
anyone have part number for the seals? the guy that works on my car is not here until next week, just want to get an idea of how much it cost. I would assume only the shaft have to come off, not the clutch and tranny. Right?
Old Dec 30, 2004 | 10:54 AM
cityhugo's Avatar
I am thinking this is the part where is leaking, but i don’t see any seal part# on the service booklet
Old Dec 30, 2004 | 11:03 AM
patsevo8's Avatar
I am with everyone that thinks it might be the seal of the CV shaft
Old Dec 30, 2004 | 11:05 AM
cityhugo's Avatar
i think so too, is a very thick oil that’s coming out. do u think i can still drive the car or i should just leave it for now?
Old Dec 30, 2004 | 11:11 AM
If it is leaking where the shaft is inserted into the housing, then the seal would be in the area of # 13 in the diagram. If the leak is on the left hand (drivers) side. #13 is a circlip that holds the output shaft into the driveshaft. Pressed into the housing should be the afforementioned seals, like a rear main seal in an engine. I haven't spent much time under my evo, but the seal should be able to be replaced after removing the drive shaft. See how much the part is and talk to your mechanic. If you can get under the car for a closer look you might be able to see if the seal is damaged. Use some brake kleen to clean the area and inspect it with a flashlight.
Old Dec 30, 2004 | 11:15 AM
If the car drives OK , it can be driven. But I would be wary of how much fluid was lost and of debris getting into the case. If you live in NY, I know there is a lot of junk on the roads. And from your pictures your undercarraige is pretty dirty. So drive out of neccesity/emergency, but personally I wouldn't be joy riding.
