ECU + minimal tuning results *pics inside*
Old Jan 5, 2005 | 05:54 PM
EvilDylan's Avatar
Originally Posted by gunzo
Prop .. I believe his image is too small and the scale too big on the ECU+ to see the changes he did ..
BJai02 could be right re on boost earlier too ..
The dip in timing is actually common for evos .. you'll see that if you smooth add 1 or 2 degrees between the midrange you'll gain quite a bit .. timings I see on JDM Evo's on boost is around 10-12 degrees between 4-6000rpms .. mine was 6-8 degrees .. check out your logs
sounds like what i have right now. I have added a degree or two here and there, but not much at all really.
I probably was on boost earlier, since its hard to get an exact start time with this thing that makes it difficult to tell.
take a look at the tps voltage, and you can see where i went WOT a second or two before the previous run.
