I have access to a Dyno, but its 2wd, how is the conversion done?
Old Jan 5, 2005 | 10:04 PM
CharlieGsanD's Avatar
Question I have access to a Dyno, but its 2wd, how is the conversion done?
The shop i work at will be getting a "Dyno Dynamics" Dyno & it looks like im going to be operating it, which means i am certian to get a bit of "personal time" on the dyno to fine tune my AEM EMS
the problem is, the dyno is only a 2wd. im aware there is a way to convert the car so it can be run as a FWD. but i dont know what is involved. if anyone familiar with this procedure could chime in & explain how its done, it would be greatly appriciated
Old Jan 5, 2005 | 10:54 PM
EricJ@AMS's Avatar
It requires welding a front diff, removing the ring gear from it, and installing it into your tcase. NOT an easy job.
Old Jan 6, 2005 | 07:23 AM
jimntjames's Avatar
I know on the VW R32 it was done by pullling slightly on the E-brake, maybe it's the same with the EVO?
Old Jan 6, 2005 | 07:27 AM
justchil's Avatar
Ouch! I always thought you just dropped the driveshaft or something.
Old Jan 6, 2005 | 07:45 AM
sleet's Avatar
I heard about that thing with the e-brake, not sure if it works with the EVO. I thought you could always just drop the drive-shaft and you'd be good but who knows.
Old Jan 6, 2005 | 08:48 AM
kcevo's Avatar
This might be correct with cars with ACD's. With a ACD you pull on the e-brake and it disengages the rear end not to put strain on the viscous coupler as you are still on the throttle. Very nice feature for rally/road racing.
Old Jan 6, 2005 | 09:09 AM
sleet's Avatar
I think I read somewhere that the 05's are able to do this, not positive tho. I'll try to find out the thread I was reading...
Old Jan 6, 2005 | 09:17 AM
Cajun Power's Avatar
If the GT-R center diff is a 50/50 diff and you pull the rear drive shaft wouldn't you only get 1/2 the whp? Why not pull the front and make a RWD EVO? That would be sweet to see an EVO doing a RWD burnout!!!! I have 325 awhp if I was to pull the FWD off would I have a 167 RWHP car? I don't know how good of a burn out that would be.....
Please don't laught cuz I don't know if this actualy would work... just thinking out loud.
Old Jan 6, 2005 | 09:19 AM
gadsmevo's Avatar
Any of you ever heard of a viscous coupling Eliminator?
http://www.machv.com/viscoupel.html
Old Jan 6, 2005 | 09:27 AM
sr20det91's Avatar
Talk to Buschur racing.
They convert their evo's to fwd for dyno tuning all the time. I believe they just disconnect the drive shaft.
Not sure about the 05's with the active center diff. as it may be a bit different.
Old Jan 6, 2005 | 09:30 AM
kcevo's Avatar
It requires this to be done as well.
Old Jan 6, 2005 | 09:33 AM
I still think a RWD EVO would be BAD AS$ ! ! !
Just for showing off and drifting.
Old Jan 6, 2005 | 09:35 AM
gadsmevo's Avatar
You can not just disconnect the drive shaft.
You need a VCE see my above post.
justchil's Avatar
Ummm no
Old Jan 6, 2005 | 09:40 AM
kcevo's Avatar
It doesn't work for the Evo though.
