368whp pumpgas (stock turbo)
Old Jan 17, 2005 | 06:13 AM
  #46
ldstang50's Avatar
Originally Posted by ShapeGSX
Uhh, you don't just drop the driveshaft to dyno an Evo on a 2wd dyno.
i know that, i was quoting our good friend and oh so knowledgeable evotexas
Old Jan 17, 2005 | 06:49 AM
  #47
Ted B's Avatar
Notes...
- Smoothing of the power curves would probably show the actual hp peak to be ~360. This is not an unusual figure for similarly equipped EVOs.
- That being said, there are EVOs without an expensive aftermarket IC or AEM EMS making right around the same power. This being the case, the mods quoted herein do not appear to represent any 'price breakthrough' revelation where $/whp is concerned. After all, there was a rather hefty $4k spent between just the AEM EMS and IC alone.
- Finally, it's been demonstrated that the hotside mod should not be expected to increase peak hp.
Old Jan 17, 2005 | 06:51 AM
  #48
ldstang50's Avatar
Originally Posted by Ted B
Notes...
Ted-
When you guys say hotside mods, do you mean the side between the intercooler and the throttle body? If so what do you mean by mods to that side? I/C pipe? or something else?
Old Jan 17, 2005 | 06:56 AM
  #49
Ted B's Avatar
The hotside mod refers to the larger housing for the exhaust side of the turbo. This does not change the internals of the turbo (or its ultimate flow capacity), but it does give a nominal boost to midrange torque potential.
Old Jan 17, 2005 | 07:17 AM
  #50
ldstang50's Avatar
ahh ok, thanks
Old Jan 17, 2005 | 08:27 AM
  #51
Geo@EvoStore's Avatar
Originally Posted by BadazzCR
Show me someone that has done that power for less money on stock turbo with pump gas (shell 93).
http://store.evostore.com/0311sepugase.html
Those are very good numbers though. We also had a customer make 331awhp and 354tq with stock cams on 93 octane. Also these are Mustang Dyno numbers.
Old Jan 17, 2005 | 08:34 AM
  #52
Ted B's Avatar
Originally Posted by Geo@EvoStore
In all fairness though, the car in the above link uses water/methanol injection, which isn't truly comparable to 93 oct pump fuel because it effectively raises the octane.
Old Jan 17, 2005 | 10:47 AM
  #53
plokivos's Avatar
still nice numbers on that white car.
I always wonder if a shop's going to build a fast car with lots of hp, reliability should always be there. Not everyone of us could afford a straight race car that doesn't last 30,000 miles.
anyway, that's my thought of the day.
Old Jan 17, 2005 | 10:51 AM
  #54
Smogrunner's Avatar
First of all, great job Doug! Seeing those numbers makes me feel glad I followed the stock"ish" turbo route. Those torque numbers are ungodly. I'll take you up on the same power for less money challenge though. First, I'd like to make one point: You should post the map you sent the customer home with. You yourself said there was some sort of a knock event at 6800 so we are really comparing a final number of 350, right?
You're customer and I actually have an extremely comparable setup so I'll just compare the differences:
I saved $1600 for the Xede instead of the AEM
I saved $450 by keeping my stock injectors.
I saved $300 by keeping my stock airbox.
I save $50 by not using manual boost controller.
I lost $950 by adding the 10.5ti (hotside is just $250)
I lost $100 for the Xedeflash
So, in the end, I saved $1,350. That is a lot of money. Had I gone with the hotside only, I would have saved $2050. Remember, all this talk about 10.5 etc is quickly becoming a mute point, as all 2005s have it stock. You did not mention what year this car was. But assuming you did it on a 03 or 04, that is impressive indeed.
Next, this map is a 91 octane map. As the good tuner you are (and I honestly believe that), you know that a significant amount of HP was left on the table for the lower octane tuning. I did not touch my tune, just dynoed it on my straight 91 octane tune. I'm sure you'll agree that I would have at least 5 to 10 more hp and at least 10ft/lb more torque than that on a 93 tune. Talk to Al and other tuners who have to play ball on 91 octane and they will tell you it is truly challenging to make big safe power on that pisswater.
Still, I am very impressed with those numbers, especially the torque. Great job.
Old Jan 17, 2005 | 11:09 AM
  #55
bryans2k's Avatar
Talking
Originally Posted by EVOTEXAS
How much is 340 AWHP on a Mustang dyno? I did that with an ECU flash included in about 1500 dollars worth of mods. I don't even have all the bolt ons yet either. If it's not 368 WHP, it's right there within the margin of error. Stock turbo, pump gas, etc. I'll put the AMS upper IC pipe on this week sometime and dyno on Feb 5th and I'll let you know my new numbers.
I don't know how much it is but I know it wasn't enough for you Sunday to be able to leave me
bryan
Old Jan 17, 2005 | 11:50 AM
  #56
EVOTEXAS's Avatar
Just responding to YOUR comment, so if my comment was elementary, it was to be on your level of understanding. Go shave your head.
Old Jan 17, 2005 | 11:52 AM
  #57
EVOTEXAS's Avatar
bryan
You know the problems I was having and you also have an upgraded turbo and I don't, among other things. It was fun though!
Old Jan 17, 2005 | 04:17 PM
  #58
TurbotrixRacing's Avatar
I can attest to the urine in the gas .. LOL.. Great numbers ..
Mark
turbotrix
Old Jan 17, 2005 | 06:24 PM
  #59
megatron's Avatar
those numbers are way crazy on a stock turbo. i think the ems is in my near future.
Old Jan 18, 2005 | 09:16 AM
  #60
ldstang50's Avatar
It was shaved but i'm out of the military now
was that MY comment? I couldn't tell since you quoted it. You might want to bold it next time just to be sure I know I wrote it.
Never argue with an idiot, first they bring you down to their level, then beat you with experience.
I got it ok, you win, I'm tapping out, I'll move to the high school threads
