Anatomy of a buildup: Mild to wild in 72 hours!
Old Jan 18, 2005 | 11:35 AM
  #46
Harman Motive's Avatar
Originally Posted by negativeB
didn't finish in the 72 hrs?
We actually finished including road tuning and some power pulls in 60hrs (10am Fri - 10pm Sun). Not bad concidering we worked this around our previously scheduled appointments. (Unplanned mod frenzies are fun )
Total install time was closer to 12hrs total (install, wiring, etc.) - remember, the car was bone stock when we cracked into it.
Regards,
Old Jan 18, 2005 | 12:35 PM
  #47
Pics
EMS, small battery, sensors
After the last few ATP kits we installed, we've been pretty liberal with the RTV on the oil return
Coming together
Fuel pump
That's a mean 4" inlet
3" Intake, no MAF of course
Precision turbo FMIC and RnR piping laid out
RnR 3" Turboback with extra-long resonator (sounds really nice)
All done
FMIC installed
Loading up the base cal. It's a boost comp map off of our A-spec car with a few mods for the new injectors and bigger turbo. Got the car running very quickly.
Strapped on the dyno and ready to run.
Needs more boost!!
Here is the best pull we could get out of the dyno before the interferance knocked it off-line. This is off road tuning only (1.5hrs) at 18psi. I was hoping to get the tuning finished, but we're stuck until we can get a proper RPM signal.
More updates to follow. Thanks for all the interest guys!
Regards,
Old Jan 18, 2005 | 12:57 PM
  #48
calhoun's Avatar
is that dyno on c16?
Old Jan 18, 2005 | 01:36 PM
  #49
haha, not quite.
91 octane California ****.
Old Jan 18, 2005 | 01:45 PM
  #50
Halo's Avatar
HOLY COW! Have some car with your RTV!!
PS: Am I missing something? Only 342whp with a GT35R?
Old Jan 18, 2005 | 02:10 PM
  #51
RnR Racing's Avatar
91 octane on 18psi. Once the car is tuned for 21psi it should make 400whp or close to it. On C-16 and 28-30psi it should make 500whp pretty easily. We have found the ignition systems to be pretty weak on the EVO's we have built here.
Old Jan 18, 2005 | 02:15 PM
  #52
cruizinmax's Avatar
We had some problems with the oil drainback tube leaking also. I ended making a piece out of the stock drainback tube.
Old Jan 18, 2005 | 02:58 PM
  #53
cruizinmax's Avatar
Here is the piece I made. Oil kept leaking around the bolt holes.
edit: helps to put the picture.
Attached Thumbnails Anatomy of a buildup: Mild to wild in 72 hours!-img_0810small.jpg
Old Jan 18, 2005 | 02:59 PM
  #54
RnR Racing's Avatar
If you use the proper gasket and RTV it works perfect. We haven't had any leak at all once you do this. This is the same set up used on the ATP kit as well.
Old Jan 18, 2005 | 05:10 PM
  #55
propellerhead's Avatar
The more I look at this kit, the more attracted I become.
EDIT: Except for that coolant pipe...
Old Jan 18, 2005 | 05:23 PM
  #56
RnR Racing's Avatar
What don't you like about the coolant pipe?
Old Jan 18, 2005 | 05:36 PM
  #57
I'm sorry. There's probably not much better of a solution short of a custom radiator with a customized outlet location. I just don't like the tight fit.
Old Jan 18, 2005 | 07:39 PM
  #58
ru4real's Avatar
Do you think it's too close or exposed to the exhaust manifold?
Old Jan 18, 2005 | 09:03 PM
  #59
Spec C's Avatar
I think some An fittings and aeroquip hose would make a better drain soloution..
Old Jan 19, 2005 | 06:53 AM
  #60
RnR Racing's Avatar
That is more a custom set up that would require mods to the radiator. We are also the only ones that include a SS radiator pipe and I have seen several kits that get close to that hose.
