Installed Dynomat,now car wont start
Old Jan 16, 2005 | 10:44 AM
yellowcar72's Avatar
Okay..Stripped out the interior and did an install of Dynomat. Went out this morning to start the car and ive got power but no fuel. The low fuel warning light is on but before i did the install i had half a tank and theres no evidence of any tampering with the gas door or cap. The only wiring i disconnected was the console itself[cigarette lighter,etc] Any clues what i could have done?
Old Jan 16, 2005 | 11:00 AM
Dookie's Avatar
Any chance the connector on top of the tank was messed with? Make sure thats still plugged in.
Old Jan 16, 2005 | 11:02 AM
Secret Chimp's Avatar
And you are sure that you didn't cut any of the fuel pump wiring while doing the install?
Old Jan 16, 2005 | 07:32 PM
gunzo's Avatar
you have either disconnected or damaged the wiring to the fuel pump/fuel level sending unit .. start from there .. or better still .. check the fuse 1st ..
Old Jan 16, 2005 | 07:48 PM
EVOtagger's Avatar
yep sounds like you probably knocked the fuel pump fuse loose...happened to my old car when installing front door panel speakers...
if not that, then check all fuel pump connections and wires
Old Jan 17, 2005 | 11:13 AM
Wont start
Sorted! I took apart a pair of connectors in the right rear to get better access for the deadner and forgot to put them back together. DUUUH. Thanks for the responses!
Old Jan 18, 2005 | 03:32 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
How do you like the Dynomat? Did it make much difference? I want a little less road noise in my car.
Old Jan 18, 2005 | 04:40 PM
EVOTEXAS's Avatar
I fully Dynamatted my floors doors and trunk. Radio sounds great, road noise is gone, exhaust is still loud as anything.
Old Jan 18, 2005 | 04:55 PM
Thanks. How much time did it take you?
Old Jan 18, 2005 | 11:14 PM
EVOTEXAS's Avatar
About 7 hrs total.
jono119
Outlander Sport
12
Nov 25, 2023 10:25 AM
ssteve
May 16, 2010 09:00 AM
drewblueeye
Aug 10, 2006 10:59 PM
army685
16
Feb 6, 2004 02:01 PM
LBLancerDude
Apr 1, 2003 09:56 PM
