Apexi Power Intake Kit with Induction Box, got one?
Old Jan 19, 2005 | 05:30 AM
Derek888's Avatar
How do you like it and can the filter be cleaned like K&N? I know cold air is not necessary for turbo cars but the aluminum box looks tight and it should help keep water out in heavy rain.
Old Jan 27, 2005 | 08:47 AM
Evo8DownUnder's Avatar
bump. i'm interested too.
Old Jan 27, 2005 | 08:56 AM
ARVSHOP's Avatar
get the box man...I have it in my car....i cant tell you how much it helps me when it does rain...it just keeps the water out completely and plus makes it look custom done
Old Jan 27, 2005 | 08:58 AM
BSREVOLUTION's Avatar
i have one. you just take the top part of the box with an hex key and then your free to clean your filter. also if you have a BR mini battery, you will have to cut your box.
Old Jan 27, 2005 | 09:26 AM
a BR mini battery?
I'm not near the evo at the moment guys, do you have to relocate the battery??
Old Jan 27, 2005 | 09:30 AM
btw, is this the item?
the mini battery extends a few inches past the fuse box so the box needs to be cut.
Old Jan 27, 2005 | 09:40 AM
Derek888's Avatar
Since the Apexi filter kit does not come with ss piping do you know which one to get that would fit? BTW if I do change the ss piping does that mean my maf would have to be removed as well?
Old Jan 27, 2005 | 09:46 AM
BJai02's Avatar
I assume you meant a piping to go with Apexi filter AND box. Any piping works with stock airbox should do the trick, such as Cusco, DejonTool, and Helix. And you don't remove your MAF sensor. The SS pipe uses a silicon coupling to connect to the OEM MAF.
Old Feb 5, 2005 | 11:35 PM
Derek888's Avatar
Besides the looks and keeping rain out do you think it will help in performance wise? Do you have to take out any stock parts out to make it fit, like battery or intercooler spray?
Old Feb 13, 2005 | 10:27 PM
Mayhew333's Avatar
I got one and I am very happy with it. It was a pain in the *** to install though. Looks pimp and it is actually really functional. I ran the car without the box and then with it and noticed a significant differance. Nothing else besides the stock airbox is removed to install.
Old Feb 13, 2005 | 10:50 PM
Rmm Rmm's Avatar
Registered User
Do you get the increased induction noise with the filter inside the box ie is it louder than the stock induction noise?
Old Feb 13, 2005 | 11:47 PM
Derek888's Avatar
With the box where does it get air from? Whats so hard about installing the box? Some say the filter was a pain but thats only because of that one bracket thats hard to reach.
Old Feb 14, 2005 | 03:29 AM
04Evo8RS's Avatar
its louder than stock in that box..but if you just have the filter bolted on that will be the loudest
Old Feb 14, 2005 | 09:29 PM
wthoevo8's Avatar
Does anybody have the installation write up or manual in English for this Apex intake and induction box?
