2nd gear grind
Old Jan 19, 2005 | 06:30 PM
evoracer32's Avatar
2nd gear grind
i have had my 2005 gsr for about 3 months now and every once and a while when i get on it and try and go into 2nd gear it just wont and starts to make a grinding noise. Any ideas on how to fix this, i have been driving stick for a while and this is the first car that does this thanx in advance
Old Jan 19, 2005 | 06:31 PM
EVIL_EVO_VIII's Avatar
Take it in to the dealer. I know there are tsb for 2nd 4th and 5th gear syncros for 03-04 but dont know if it applies to 05.
Old Jan 19, 2005 | 09:22 PM
evoracer32's Avatar
yea thats wut i was thinking but i have a buschur stage two so they will probly not want to fix wutever is wrong, i was wondering if maybe some metal shifter bushing would help or short throw shifter, any imput
Old Jan 19, 2005 | 09:23 PM
escoson's Avatar
is it def. a grinding or is it more of a notchy feel?
Old Jan 19, 2005 | 09:31 PM
evoracer32's Avatar
its deff a grinding noise and it wont go into gear, its strange cause it will only do it every once in a while
Old Jan 20, 2005 | 08:31 AM
newevo8's Avatar
I just got my o3 back from the dealer with a similar problem.
they replaced:
3rd gear and 4th gear.
All 1-5 synchros
new fork.
new clutch. to bearing. pressure plate
all new shims
all new spring and parts needed to rebuild my tranny
I still have a freaking 3 and 4 gear grind. I think there is not enough clutch fluid pressure in the system. they need a bigger booster is my guess.
Old Jan 20, 2005 | 08:50 AM
hkfeet's Avatar
I figured out that if I shift at higher rev's, 4500+ there is no noise or notchy feeling.
Old Jan 20, 2005 | 06:35 PM
Its really up to the dealer if they want to cover it. Have they seen you car mods? If not then you can take them off if it doenst bother you and take the car in to service. Havent heard of any tsbs for 05's but its possible.
Old Jan 20, 2005 | 06:36 PM
they replaced:
All 1-5 synchros
new fork.
all new shims
What happened to your 3rd and 4th gears?
Old Jan 20, 2005 | 07:17 PM
Mercenary3's Avatar
There has been A LOT of discussion on this. Searching might help the cause. I had a similar problem with my 05 gsr (also about 3 months old) Took it in, they drained the trans fluid...found no metal shavings...filled it up with a new fluid and took it for a drive. Since then the problem is much better. IDK how cold it is where you live....but for me...the trans does not like cold fluid in it. It will shift like crap until you warm it up A LOT. Ive heard stories of dealerships filling the trannies with wrong fluid types, etc....so that might be youre problem also.
Anyways, after I got my fluid changes, the car is still a little notchy, but it doesnt grind. You still have to rev match almost every downshift perfectly though to get good shifts.
Old Jan 20, 2005 | 07:19 PM
Mercenary3's Avatar
Also, a lot of people have reported that this type of thing dissappears after the car gets a couple thousand miles on it. If its grinding bad though I would take it in....in stock condition.
