Best Turbo for midrange power?
haha.. if you don't even have an EVO yet, how do you know you're gonna need to upgrade turbos? Anyway, the stock turbo is more than sufficient for what you're asking for. The 05s should have even better midrange w/ the 10.5cm hotside.
Originally Posted by sleet
The 20G is going to blow the br500 out of the water.
I now have the BR500bb turbo on the car is it is just insane how fast it is. 26lbs of boost and the car is all over the road in 1-3 gears. The car was running 11.90's before the new turbo and now it makes the 11.90 stock turbo feel slow. It makes 26lbs by 4000 or so, not much behind the stocker. Unless you are going to do ALL of the supporting mods the turbo is the very last think I would touch!
never driven one, but after being to several of the lemans races, i've learned enough to know that a stock evos gearing will benefit more from a 30r than the stock turbo.
Tho, I guess my opinion really depends on the course
Originally Posted by EVO8LTW
I have my doubts about the benefit per dollar of the Buschur ported head considering that it's more than half the cost of a turbo kit and as much as the upcoming 20G upgrade. Since you have one can you comment on that?
On the stock turbo the car built boost instantly and I think some of that was from the head. I hope Dave will be able to do the head comparison on his RS build up. Al did comment that he thought the top end of the moter was one of the quitest he has heard, maybe that is help with the knock sensors hearing less noise. Just some thoughts.
BR Stage 1-4
BR Stage 3 head
HKS 272 and gear
AEM EMS
BR Water Injection kit
Upcoming 20G
Exedy twin with clutch line
Omnipower coilover
Cusco front anti roll bar
Perrin Endlinks with Swaybar
This is the fastest way and cheapest to get your power up
BR Stage 3 head
HKS 272 and gear
AEM EMS
Upcoming 20G
Omnipower coilover
ecuflasher
157
Mar 5, 2008 07:07 AM
EVIL_EVO_VIII
42
Oct 12, 2006 07:53 PM
20, adding, evo, evolutionm, fast, good, mid, midrange, power, range, spool, turbo, turbocharger, turbochargers, turbos
