Guess my HP increase!
Old Jan 24, 2005 | 10:33 PM
IEXCELR8's Avatar
Getting a Magnus intake and TB installed at TT this Saturday. What do you think I will see as an increase in HP/TQ. I am guessing 28hp/25tq. Mods are in my sig. It will be dynoed after the install.
I will let everyone know what I get next Saturday night.
Mike
Old Jan 24, 2005 | 10:37 PM
UT_Evo's Avatar
so an intake and a slightly better TBE system? Cat-delete or not?
Old Jan 24, 2005 | 10:51 PM
johnnysixer's Avatar
Way more than that. You should be getting the power you said by just the exhaust! (depending on catless or not) Are you running this without a reflash? Because of the intake you will loose some torque overall. Good luck, and post up your results!
Old Jan 24, 2005 | 10:54 PM
UT_Evo's Avatar
He already has an exhaust and downpipe...read his sig...he's just upgrading
Old Jan 24, 2005 | 10:57 PM
IEXCELR8's Avatar
These are my current mods and hp/ tq numbers.
AEM EMS,UEGO WIDEBAND/GREDDY BOV/K&N FILTER KIT/HKS 272 CAMS/WALBORO FUEL PUMP/RMR DP/RANDOM TECH HFC/DC SPORTS EXHAUST/HALLMAN PRO BC. 333.53WHP/333.77TORQUE.
I am adding a Magnus Intake manifold and 75 mm throttle body then getting it dynoed.On the stock injectors unless they have them in stock when I get there.
Mike
Mike
Old Jan 25, 2005 | 02:13 PM
Ted B's Avatar
I doubt you'll get anything at all from the larger TB. It will change throttle response significantly, but I doubt it would change the dyno graph at all. Any improvement you see I'd attribute almost entirely to the intake manifold.
And where that is concerned, you stand to get something from the intake manifold, but the trend seems to indicate this to be at high rpm. My only concern would be that the stock turbo may not have enough puff left at that rpm range to realize the full benefit.
I think it's anyone's guess, and it will be interesting to see what happens.
Old Jan 25, 2005 | 02:24 PM
Gevo's Avatar
6.53 whp
Old Jan 25, 2005 | 03:55 PM
Kaane's Avatar
6.54 whp
Old Jan 25, 2005 | 09:21 PM
bolsen's Avatar
I'm with yah. Your gains would be MUCH higher had you have an aftermarket turbo. But with the stocker, you certainly could have spent that money more effectively else where.
On that note, you are buidling a good foundation for something big!
Old Jan 25, 2005 | 11:02 PM
IEXCELR8's Avatar
Well I plan on putting a turbo upgrade on around spring time and that is why I picked this up. Also I may look into some head work/ valve and springs/fuelrail ect.
Mike
Old Feb 1, 2005 | 04:07 PM
IEXCELR8's Avatar
Well I got a tad under 10hp all across the power band, much more sensitive response and it keeps pulling where i dropped off before. Come spring it will help with a larger turbo upgrade. I have not decided on what kit to get yet.
I have to tell everyone there is a lot of modifications that need to be made to make this work. Custom upper pipe, dipstick,and a few others that Mark from TT could tell you better.I also had a bigger TB which needed some customization done to it.
I don't regret it as it will be beneficial at a later date with the turbo upgrade along with an alcohol kit.
Old Feb 1, 2005 | 04:29 PM
bolsen's Avatar
Cool. Now just get the 30r and be happy
Old Feb 1, 2005 | 04:35 PM
IEXCELR8's Avatar
Some kind of kit anyway, man I want it now and I am only a few bucks short.Time to save quick!
Old Feb 1, 2005 | 04:49 PM
sonics36's Avatar
What Up Exceler8 I Met You Today How's The Car Runing?
Old Feb 2, 2005 | 10:57 PM
David Buschur's Avatar
8-10 whp, maybe.
David Buschur
www.buschurracing.com
ThatchMoney
Feb 15, 2017 11:16 AM
reelbite
Feb 4, 2014 02:29 PM
Appauldd
Mar 31, 2009 09:22 PM
evogottago
10
May 16, 2008 04:03 PM
purecoda
Oct 26, 2004 07:45 PM
