HKS EVC HIts boost cut @20psi HELP!
OK... im completely baffled...
I installed my EVC V and have the wastegate set at 60% and then had it set up correctly, running good 20.5psi coming back to 17-18psi...
Its good for the first couple times after a coldstart (warmed up of course)
Then I hit boost cut at 4,500 in second gear, then i tried 3rd and hit boost cut at 5,500rpm
I wouldn't dare take it higher because im scared....
My low boost is set at 50% wastegate and i have no problem, its like stock 19psi then down to 16...
Can someone help me
MODS:
ARC intake
HKS EVC
STock BOV
Megan Racing Turbo Back
Thats all ihave done right now
Can someone help me
MODS:
ARC intake
HKS EVC
STock BOV
really?
Cause yesterday afternoon when i was running around when it was keeping it at 20.5 the whole afternoon no problems
then when it got colder at night it kept hitting boost cut
Originally Posted by lemacfar
really?
Either do a reflash to get rid of the fuel cut, or even AFC can be tuned to lean out the mixture. With the mods you have, you may be at high 90 to 100% injector duty cycle without ECU tuning.
Originally Posted by BJai02
Colder air needs more fuel to compensate. If you hit a "cut" at colder weather at the same boost level, it sure is a fuel cut. Boost cut doesn't kick in at 20-21 psi...
are those gramlights 57Fs on your avatar
