Which 4G64 is best for EVO?
Old Feb 1, 2005 | 09:09 PM
Zeus's Avatar
Originally Posted by MalibuJack
Yep.. the Eclipse block and one other car (I think an SUV model) has an engine suitable to be used in the Evo Chassis where it would bolt on.. For the most part the only major external difference is the deck height is about .25" taller so you need the longer timing belt and of course, there's a space between the lower timing cover and upper cover of the 4G63 Evo head.. I don't think much else needs to be changed other than prepping the crank and using beefier rods and pistons.
Do all the accessory brackets bolt into place also though?
Old Feb 1, 2005 | 11:40 PM
Yogi_B's Avatar
Originally Posted by housedj
mitsubishi FTO.
The FTO's never came with a 4G64, they only came with a 4G93 and two different 6A12's, a mivec and non mivec.
Old Feb 2, 2005 | 05:04 AM
MalibuJack's Avatar
AFAIK it has everything needed to make it a bolt-in swap.. Which is why these particular blocks were recommended to me.
I will go through my notes to find out which two specific blocks and cranks were recommended. These were recommendations by two different builders who have both built some potent 4G64 stroker motors with Evo Heads here in the northeast.
black_beauty
May 18, 2016 10:34 AM
senate6268
128
Sep 3, 2015 10:44 PM
bryonboals
For Sale - Miscellaneous Automotive
10
Sep 23, 2012 08:58 AM
sktng22
Dec 2, 2011 10:30 PM
dsevo
Mar 25, 2010 08:29 AM
