View Poll Results: Best Drop In Filter
K&N
23
82.14%
Ralliart
10.71%
Monstersport
0%
HKS
7.14%
Voters: 28. You may not vote on this poll
Best Drop In Replacement Filter
Old Feb 1, 2005 | 07:20 PM
TurboWill's Avatar
Question Best Drop In Replacement Filter
I have a K&N drop in. I know there are a few on the market. I am concerned that to much dirt is getting through( Rumors ive heard?) Anyone switch companies for any reason?
Thanks
Old Feb 1, 2005 | 07:22 PM
bolsen's Avatar
You're fine. Just clean regularily
[/thread]
Old Feb 1, 2005 | 07:27 PM
TurboWill's Avatar
[/thread]
They sell a K&N cleaner kit on Lancershop. I'm going to buy it.
Old Feb 1, 2005 | 10:50 PM
IOevo's Avatar
i have an HKS drop in... and the bottom of my air box is kinda dirty... im prolly switching back to stock soon....
Old Feb 2, 2005 | 02:53 AM
RaceBiscuit's Avatar
bump for more responses. I'm curious about this too. Does the K&N REALLY cause any kind of problems?? I keep hearing "gossip" about it but I've always used them on other cars without any problems. eh??
Old Feb 2, 2005 | 08:14 AM
bonestockevo8's Avatar
I am using a Blitz LM drop in filter. Performance wise, I'm pretty sure all the drop ins are around the same (1 hp or so increase, if that)...as far as filtering efficieny, I like the Blitz unit because it utilizes a steel mesh type material.
Old Feb 2, 2005 | 10:15 AM
bolsen's Avatar
K&N filters have been around for a LONG time, and in many cases more effective for stopping dirt, especially over a longer period of time than the foam filters.
K&N says clean it every 50k. Try doing that with your HKS foam
Old Feb 2, 2005 | 11:45 AM
TurboWill's Avatar
Honestly with my K&N drop in I noticed the turbo spooled a bit quicker vs the stock air filter.
Old Feb 2, 2005 | 01:31 PM
GTKage's Avatar
k&n is the way to go, been around for a long time and as long as u clean it every 20k-30k miles u will always have good performance from it. I have notived too better turbo response with it. And those rumors about letting more dust inside the engine is more true when it comes to foam filters.
Old Feb 2, 2005 | 01:35 PM
Honestly that is probably the result of a placebo effect. If not though, more power to you.
Old Feb 2, 2005 | 01:38 PM
jj_008's Avatar
Stock.
Old Feb 2, 2005 | 01:46 PM
mttam510's Avatar
revision
BMC...only one that I have seen that actually makes power. Franz @ KTR perf tested a wide assortmanet of filters and CA intakes, and the BMC drop in using the factory airbox made more power consistantly over all others he tested. A few front running ALMS and Grand-Am teams are running BMC filters....and hey Ferrari F1 teams uses as well.......
Old Feb 2, 2005 | 02:44 PM
k270kmh's Avatar
BMC? WHere can I find more info?
Do you have results with K&N vs BMC?
Old Feb 2, 2005 | 02:55 PM
oguratevo's Avatar
Ralliart is the way to go. Been using this since the start. Designed for the Evo
Old Feb 2, 2005 | 03:01 PM
oguratevo's Avatar
I heard a problem on putting too much oil on the K&N filter element will cause some oily/greasy build up around the airbox.
