solution for sti battle...FQ!
Old Feb 18, 2003 | 11:49 AM
  #46
DiscoZ's Avatar
Originally posted by Turboniam
DiscoZ
Actually, for me, the reason is the larger motor... mod for mod the STi will be faster.
That is incorrect. There is no replacement for displacement, if and only if, all else remains equal; There are too many variables in this situation. Would you care to explain why the 2.6 ltr RB26DETT can make more power, dollar for dollar (or yen for yen, if you would), than a 3.0ltr Mitsu GTO motor?
I'm a drag racer, not an auto-xer, so that is why I want the "stroker" motor.
Do you even know what a, "stroker", motor is (i.e. increased displacement as a result of the rod-ratio being altered with a longer stroke and thus, increased mid-range torque as a result of a longer, more forceful thrust)?
If you are indeed a drag racer, you are looking at the wrong car buddy.
Cheers.
Old Feb 18, 2003 | 11:55 AM
  #47
trigeek37's Avatar
Originally posted by Cordwood
I bet the EVO weighs at least 200 pounds more than the STI
that's pretty doubtful. the Evo weighs less then 200 lbs more then the standard WRX. (3080 vs 3240) The STi will most certainly weigh more then the WRX (the 6-speed is something like 80 lbs more). Larger brakes, intercoolers etc aren't excatly weight-free. Don't get me wrong, they are excellent upgrades, and I think the STi is gunna be a great car, but I would bet that it turns out to be heavier then the Evo.
Old Feb 19, 2003 | 12:21 AM
  #48
3171's Avatar
I have run on the track with many WRXs, STis and RAs. Except for one (which has a really good driver and significant mods) they usually cannot keep-up. I have also seen a number (at least 3) blow their engines.
Scoobies are nice, but the engines are not strong and they don't take modification well (that's why they are going to the 2.5l engine). However, they are more comfortable cars and much cheaper to run.
Old Feb 19, 2003 | 12:22 PM
  #49
indica's Avatar
as heated as this STi vs. EVO8 discussion is getting we are gonna have some fun at the track and on the streets this year. I just can't wait to race some good old fashioned American sports cars and and smoke them like a blunt. I know quite a few **** talking muscle car owners around my neighborhood who are in for an **** whooping. and after stomping them in the 1/4 busting a 180 drift and getting back to the starting line before they even find a place to turn around.
Old Feb 20, 2003 | 05:32 PM
  #50
ModAddict's Avatar
Originally posted by cagri
I would say even 19 psi is pretty damn high on pump gas as a stock car. Running 22-23psi on 91 octane with knock and bad timing would not yield you more hp than running it on 19 - 20 psi with more timing and smooth timing curve... It can get even worse on hot summer days... I wish the car was runing around 16-17 psi stock and making the claimed 270ish horsepower...
Boost at WOT is 19psi @ 3500rpm, and 16.24 @ 6500rpm
Originally posted by CooperAWD
Thats not necissarly true. (just based on displacment)
Some cars respond better to boost etc... look at the diffrence in displacement from an RB turbo series engine to a 2jzgte. Or an Ls1 to a "mod motor" stang... allthough the Ls1 starts with much more dissplacment, and horsepower... once you get into power-adder modifications, the LS1 hasnt produced the numbers that the 4.6's have...
Don't even get me started on this one, NICE TRY! The 4.6's need the power adder mods just to keep up with the LS1's. You haven't seen to many turbo/blower LS1's have you. Let's just say the 4.6's aren't even close......nice try.
Old Feb 22, 2003 | 11:38 AM
  #51
EvoDaWayToGo's Avatar
Originally posted by LancerEvolution
These packages will probably come from the dealership so I doubt it'll void warranty since it came from the dealership.
Perfect... Just what I was looking forward to
spooln3
North Texas Evo Club (NTEC)
10
Jun 20, 2013 05:39 AM
B4IFLY
Apr 26, 2006 04:09 PM
nightfire115
13
Feb 3, 2005 01:57 PM
redrumrudy
May 20, 2004 10:30 PM
EVOJOE
European Forum
Jul 4, 2003 02:06 PM
