"How To Lie With a Dyno"
Old Feb 8, 2005 | 01:33 PM
Evol_VIII's Avatar
Heatsoak plays a big part in 4th geat dyno pulls since most of the time there isn't enough airflow for the intercooler.
Example: In my GTI I couldn't make a good 4th gear pull on the dyno with the stock SMIC. It would break up on the top and you could see the timing pull. So I had to dyno in 3rd gear all the time snce it was a shorter pull. I built my own Liquid/Air IC for the GTI where air flow isn't an issue and I made 15whp and 14ft/lb more on the same 3rd gear pulls. I then tried 4th gear pulls and I picked up almost 30whp and 20ft/lb over the broken up timing pull runs. Once I was able to make 3rd and 4th gear pulls the 4th gear pulls made more power than the 3rd gear pulls all the time.
Old Feb 8, 2005 | 07:01 PM
Willie Dynamite's Avatar
Shouldn't third gear pulls be higher then fourth do to the gear ratios?
Old Feb 8, 2005 | 09:49 PM
ERGO EVO's Avatar
Originally Posted by Willie Dynamite
'04 and stock.
Ah, now it makes sense. I see that you're in PA. You guys get what...93/94 octane?
Old Feb 8, 2005 | 09:51 PM
ERGO EVO's Avatar
No, ideally you should dyno in the gear closest to 1:1. You didn't read the article that started this thread did you?
Old Feb 9, 2005 | 08:16 AM
I did but in most cases I have seen third has put up higher numbers.
nongan
Future Lancer / Evo Models
10
Oct 6, 2007 02:29 PM
NocturnalEVO
Apr 22, 2007 11:47 PM
ak47po
13
Jan 31, 2007 04:35 AM
loj68
For Sale - Cars For Sale
21
Dec 5, 2005 01:40 PM
jbigelow
Mar 23, 2005 10:56 PM
