Read This!!!!!!very Important To All Evo Owners
Originally Posted by ultraflip
i went to check this out on my hks type 1...
turned it off.. set it for 2 min...
looked at the voltage... stayed at 14+ volts like 14.2-14.7...
voltage fluctuation at that rate shouldn't cause for any concern right?
Originally Posted by WHTEVO
doesn't matter if you tell them if it for a evo or 2g dsm. they are the same. all manufacturers use the same harness. they are all compatible with eachother. they all use the MT-6 harness. greddy is supposed to be making a new one specially for the evo maybe with a resistor in it or some type of thing.
Originally Posted by SilverEvo8owner
My greddy TT doesnt even keep the car running anymore. It just shuts off and i cant get it to work. Does anybody else have this problem?
Originally Posted by UT_Evo
Uh, yeah, thanks for the repetition...like I said, unless you were stupid and bought one that didn't say what car it was for, you'll all be fine
Holy crap, that's what I said in the first post...mine was too old to even say it was for the Evo...it says it's for the 2g Eclipse.......or was your first post trying to say that using the 2g that is the same as the Evo ruins the Evo?
I have also never heard of this.. in fact... has ANYONE on the board other than the original poster heard of this or seen anything like this??? you would think if it was common that at least someone else would have had it happen to them... ?
Originally Posted by tokeone
mt-6?
the harness is Greddy TT-14-43M
if you have a "hiccup" when you turn off the car you need to chang the blue and green wires (ig1 and ig2)
Hmm, if it's a low voltage problem, a simple relay could solve that issue...
Oh well, chalk up another reason why I don't use a TT. I'll stick with staying out of the boost for 3 or 4 minutes before parking my car.
I think you're getting two different things mixed up here. The Greddy emanage has fried some coilpacks. Greddy has made an adapter harness that is supposed to address this. The problem seems to occur when the engine is off and the key is in the on (run) position. The emanage energizes the coils, but since the engine isn't running the coils can't discharge, they overheat, and they burn up.
I don't see any way that a turbo timer could harm the coils, especially when the engine is running. I've had a 2g TT harness in my Evo since 60 miles (now at 29,000 and almost 2 years) with no problems, and with the hundreds of TT's installed on this board I'm positive we would have heard about this before now.
Your shop is talking about the emanage, not a turbo timer.
i just got my greddy tt with harness two days ago, i ordered through lancershop.com. everything is in japanese. but its just a plug and play, everything should work and not kill my precious car right?
