Read This!!!!!!very Important To All Evo Owners
Old Feb 16, 2005 | 02:18 PM
  #46
UT_Evo's Avatar
Yeah, it's probably the Emanage, I've heard of problems with that...
***this Is A Chain Letter, Please Forward This To 10 Of Your Friends And Be Sure To Say "the Harness Is The Same For The 2g And The Evo"***
If You Do Not Forward This, You Will Have Bad Luck On Valentines Day And A Little Boy In Kansas Will Not Get His Wish And He Will Die Of Cancer.
And this is really funny!
Old Feb 16, 2005 | 02:19 PM
  #47
EVOTEXAS's Avatar
992GNT is correct. The coilpacks are fried with the Greddy Emanage (only with the ignition harness installed). A turbo timer does not have any components or funcionality to affect your ignition system. It simply delays the kill signal when you pull the key out. A HARNESS certainly is not going to change voltages of your system considering a harness is an extension of wires and nothing more. Everyone relax.
Old Feb 16, 2005 | 02:23 PM
  #48
EVOTEXAS's Avatar
I called the shop and they said that the ignition does not fire properly with the ignition turned off. How the ECU sees the ignition off when the turbo timer is functioning properly is beyond me....
However, this makes me wonder if our P0300 codes are caused by turbo timers. Is there anyone out there getting the code with no TT?
Old Feb 16, 2005 | 02:24 PM
  #49
sleet's Avatar
I've had the apexi turbo timer for over a year and no problems yet.
Old Feb 16, 2005 | 02:32 PM
  #50
tokeone's Avatar
since reading this i started looking at my volt meter (which is always a hair under 14 volts while idling)
if i turn my lights on or pull up on my window switch (with the window shut) it pulls my volts to around 13 then back up to its idle volt.
when i turn the ignition off it drops to around 12.5 and back up to its operation volts
if this helps shine any light on the subject for anyone.
ive had it like this for 15000 miles/5 months with no issues.
Old Feb 16, 2005 | 02:33 PM
  #51
rlazer5000's Avatar
I've had my greddy TT for over a year now and I haven't had any problems of that sort. My only issue is that when the TT is down counting down, it shuts down and automatically turns itself back on. The stupid thing drains my battery like crazy.
Old Feb 16, 2005 | 02:41 PM
  #52
EVOla_VIRUS's Avatar
geez....next thing theyll say is my blizacks are causing my temperature dial to get stuck in the middle
Old Feb 16, 2005 | 08:24 PM
  #53
GWDEVO8's Avatar
I was getting the po300 befor I put the TT in and I am still getting the po300. Even after the the reflash.
Old Feb 17, 2005 | 09:14 AM
  #54
RAWMR's Avatar
"all manufacturers use the same harness. they are all compatible with eachother. they all use the MT-6 harness. greddy is supposed to be making a new one specially for the evo maybe with a resistor in it or some type of thing."
Just ordered a Bltiz DTT X. Can I just order the New harness from Greddy and use it?
RAW
Old Feb 17, 2005 | 09:18 AM
  #55
ldstang50's Avatar
I just received my greddy turbo timer and harness. I'll see if i can't get pics up tonight of them. Not installed yet
Old Feb 17, 2005 | 09:22 AM
  #56
ldstang50's Avatar
you can see the harness still in the package on the bottom right
Attached Thumbnails Read This!!!!!!very Important To All Evo Owners-dsc00083.jpg
Old Feb 17, 2005 | 10:31 AM
  #57
hotrod2448's Avatar
RAW
You don't need a new harness this guy was just misinformed.
Old Mar 8, 2005 | 04:37 PM
  #58
J8dailo's Avatar
hey...im kinda worried now... i was about to get the apexi turbo timer with evo harnesses... would that cause problems for my evo?
Old Mar 8, 2005 | 05:59 PM
  #59
Shaker Motorsports's Avatar
Why are people panicking? This has happened to a couple EVOs right? At a single shop, right? I have had my blitz for 2 years with no problems. Get all the facts before worrying.
Old Mar 8, 2005 | 08:44 PM
  #60
2MANYCARS's Avatar
Turbo timer causing problems? That's the weirdest thing I've ever heard. I've got one on my MR since day 1, works perfectly. I also have a Blitz TT on my WRX for the past 2.5 yrs, no problems at all.
