People using the Profec B Spec II
Old Feb 13, 2005 | 08:42 PM
EVOTEXAS's Avatar
Please post your settings and what boost it is running with those settings. I know every car will respond differently but I hope to get some sort of average or general range for each one. Please list your:
SET
GAIN
SET GAIN
Thanks!!
I have to run SET to 70-75% to hold only 21 psi when I think it should be low 60's. I have no leaks and I can't figure out why I am having such a hard time. I programmed a friends and it holds 21 psi perfectly at 63%. I have had large variations in advice both from veterans and this websites How To forum as well. Help me figure out what is wrong. Thank you.
Old Feb 14, 2005 | 09:20 AM
EVOTEXAS's Avatar
bump
Old Feb 14, 2005 | 09:39 AM
bryans2k's Avatar
Might just be the stiffness of your wastegate spring etc... It's going to be a possible large window. Somethings just can't be copied from other setup's...
bryan
Old Feb 14, 2005 | 09:42 AM
EVOTEXAS's Avatar
bryan
Yeah but I would think the relationship between the numbers would be the at least similar and that is what I am looking for.
Old Feb 14, 2005 | 09:44 AM
SterlingEvo's Avatar
I'll check my settings when I get home... I'm driving my wife's Echo today But hey... 40MPG
Old Feb 15, 2005 | 06:58 AM
PVD04's Avatar
For 21 psi, my settings are:
SET: 53%
GAIN: 6%
SET GAIN: 13 psi (130)
Although I do have to change the set quite a bit as the temperature changes. These settings are good around 30-40F. When it was down around 10F I had to lower my SET to 49%. Mods are in my sig.
-Paul
Old Feb 15, 2005 | 08:10 AM
EVOTEXAS's Avatar
Thanks! I figured out what I had wrong. I left the plastic cap on the unused port and that will F* it all up!
Old Feb 15, 2005 | 08:46 AM
That'll do it Like Paul said above, I check my boost almost daily in the winter here in VA. It's like 65deg outside one day and 25deg the next. Those temperature swings change my boost as much as 2-3psi... You probably don't have to worry about that as much in TX.
saiyanzzrage
Oct 15, 2007 10:07 AM
evo8fl
Jan 5, 2007 02:22 PM
RichJ
May 17, 2004 03:47 AM
evolutionist
Sep 20, 2003 05:01 AM
