Hks 280 Cam Specs
Old Feb 17, 2005 | 09:57 AM
dcorn's Avatar
^^^yeah man, good vids. Idle sounds pretty normal on both sets of cams, but still bad ***. My friend has stage 2 head/cams in his C5 vette and the idle is killer choppy so these are way better. I know thats a V8 but still.
Are you runnin those with cam gears and a tune?
Old Feb 17, 2005 | 10:01 AM
SilverEvo8owner's Avatar
definately not working for me
Old Feb 17, 2005 | 10:02 AM
Evo_doer's Avatar
Originally Posted by 2k4EvoVIII
Hmm are you right clicking and saving as??? Seem to work for me. If you are and it still isnt working i will post them on a different server.
Chris
Please Do, A security code comes up when I rt.Click
Old Feb 17, 2005 | 10:04 AM
2k4EvoVIII's Avatar
Ya i just dropped those in last night so the tune is all the same as what the Tomei were set for. I will be tunning the AEM tonight to see what i can get out of them. Running Findanza Cam Gears but right now they are set to 0/0.
Chris
Old Feb 17, 2005 | 10:07 AM
2k4EvoVIII's Avatar
OK well if you want to get onto IM i will just direct connect with you.
Chris
Old Feb 17, 2005 | 10:08 AM
umiami80's Avatar
QUick question. How does teh EVo Handle a Balance Shaft Removal?
WOuld People Running 272/272 on STOCK turbos benefit from 280's?
Old Feb 17, 2005 | 10:31 AM
2k4EvoVIII's Avatar
The balance shaft removal was good in letting the engine rev better but now im experiencing high oil pressure. So im actually looking into a couple different ways to solve that problem. One just flipping the bearing back around but then you might starve the engine for oil in spots that has low oil pressure or just swapping the bearings around and putting the shaft back into place without hooking it back up which i think would work fine but there is also another method that you drill out a oil gullie bigger then it is and it solves it. Old DSM trick
Chris
Old Feb 17, 2005 | 10:39 AM
umiami80's Avatar
How much higher? Enough to cause damage?
Old Feb 17, 2005 | 11:23 AM
MO_EVO8's Avatar
Nice vids chris..
Old Feb 17, 2005 | 11:41 AM
Evojun8's Avatar
so are cams worth getting for a stock turbo. makes a big diff.
lancealot72's Avatar
Nice info chris, you are going to have to a take me for another ride when you get everything tuned.
Chris gave me a ride in his car with his previous set-up, my reaction was like when you first get the evo, another ear-to-ear grin for awhile.
Nice ride Chris.
Lance
Old Feb 17, 2005 | 11:47 AM
2k4EvoVIII's Avatar
Well its pretty damn high. I see around 120-140psi at WOT. The problem im having is the pressure is so high that its blowing into my cylinders causing me to lose power for one and for 2 blow out a nice trail behind me. I did a compression test and everything is fine its just the piston ring clearance on the ross pistons is very very wide (basically you see this on race engine to allow the pistons to expand when they heat but they chatter when they are cold)
Anyway soon as my new gasket kit comes in i will be taking it back apart and see what i can do to solve this problem.
Chris
Old Feb 17, 2005 | 11:49 AM
2k4EvoVIII's Avatar
Originally Posted by MO_EVO8
Nice vids chris..
Thanx i hope they help some people out in there decision.
Chris
Old Feb 17, 2005 | 11:55 AM
2k4EvoVIII's Avatar
Cams make a huge difference nomatter what. I dont think that the HKS 280's is the right decision for a stock turbo setup though IMO. I think you would be better of with the HKS 264/264 or HKS 272/272 or the Tomei 260 Procams or a mix of the HKS cams 264/272. I jsut believe that 280 deg of duration is way to much for a stock turbo setup. I think it will hurt you in the long run. But i do agree that cams is one of the best mods you can do for your car. The EVO really wakes up in the top end department with them.
Chris
Oh ya there are allot of other cams out there now that i have not experimented with. All the specs are about the same though on all the cams for the evo. The one set that i have heard good things about are the Revolver cams but i have not seen any dyno's of them. I have heard a video with them and they sound very lopey for the duration they are. But i believe the guy did not have any engine management to work that out. Another is the Piper cams and the new Tomei cams look very very good. But agian they are made for a full race setup with upgraded turbo. If you look at lift wise the Piper cams come in 1st with 12mm of lift which is just crazy!!!. The Tomei cams are known in Japan as the king of all cams when it comes to EVO's and they know what they are talking about and they come in 11.5mm of lift. Anyway so much information if anybody wants to know more im more then willing to help out with what i can.
Old Feb 17, 2005 | 11:57 AM
2k4EvoVIII's Avatar
Nice ride Chris.
Lance
Lance:
Man i have been trying to find you. I was going to see if you were interested in the Tomei cams i had for sale but i couldnt get ahold of you. Anyway long time no talk how have you been? You know AutoX started last weekened!!! Too bad my other engine wasnt done or i would go. But i would just get blown away with this setup . Anyway PM me and we can set somthing up to get together.
Chris
