Hks 280 Cam Specs
Old Feb 18, 2005 | 09:53 AM
  #46
2k4EvoVIII's Avatar
Originally Posted by Ted B
Until someone can furnish lobe centers for cams like Tomei and JUN, there is no way to compare apples to apples.
For example, if one runs a set of HKS cams (any of them) at 0/0 setting and swaps in a set of Pipers, the engine sees the Pipers at -3/-2. Naturally, this makes a difference one will see on the dyno, and the seat of the pants as well. Of course, one isn't aware of this unless he knows the specs. This being said, if we want to see the difference between any HKS set and the Pipers, we need to retard the Piper intake cam 3 deg and retard the exhaust cam 2 deg.
This is why we cannot really compare advertised duration numbers between cam makers and even lift numbers are of limited value for comparisons unless we know where that lift occurs with one cam set with respect to another cam set.
Just FYI.
This is very true. And i have the cam spec cards showing everything from both the HKS 280 and the Tomei 260. I will try and scan them in and post them for you. Most people wont understand what they are looking at but it still is good to know. But in if you can see a 15whp or up difference the difference you will see retarted the cams to equal is very unlikly to pickup that much of a difference. So you still can get a good idea of what you are looking at. Just like dave installed the 280's over the 272's and picked up a additional 25whp. AMAZING! And i dont care how much you mess with the timing you wont be able to pick that much power up nomatter how you look at it. Just my 0.02
Chris
Old Feb 18, 2005 | 10:04 AM
  #47
Ted B's Avatar
FWIW, I noted a difference of 10whp just by changing the timing of the intake cam 3 deg with the same cam set.
How is this?
The single most important valve event is the point where the intake valve closes. If we take a cam set like the HKS 280, even installed at the same lobe center as the 272 set, what happens is the closing of the intake valve is delayed, which is going to benefit our higher rpm HP with no other timing changes. The tradeoff is inevitably increased overlap and low speed cylinder pressure, which will make the motor a bit more soggy off-boost (which causes the rough idle).
This also explains why installing the Pipers at the same setting will likely result in less higher rpm power and better low speed power. Why? Because the Piper cams are advanced in comparison to the HKS cams (notice I corrected my previous post to show +3/+2). Want to make the Pipers behave a bit more like the HKS? Take your HKS timing and spin the sprockets to retard the int 3 deg and the exhaust 2 deg when you install the Pipers.
In any case, if you post the cam cards, we'll be able to compare apples to apples.
Old Feb 20, 2005 | 02:25 AM
  #48
Yaroslav's Avatar
what is the duration of TOMEI 280?
Old Feb 20, 2005 | 07:49 AM
  #49
Z1 Performance's Avatar
that is the duration.....
Old Feb 20, 2005 | 08:16 AM
  #50
2k4EvoVIII's Avatar
Duration is 280
11.5mm of lift on both intake and exhaust
I heard they are coming out with a 11.8mm lift cam though?
Chris
Old Feb 20, 2005 | 08:17 AM
  #51
2k4EvoVIII's Avatar
Hey good to see you could make it...lol... BTW i got the HKS 280's from Z1. Fast shipping and a great price!
Chris
Old Feb 20, 2005 | 08:20 AM
  #52
nabit's Avatar
very nice info,thanks man!!!!!!!
Old Feb 20, 2005 | 08:25 AM
  #53
Yaroslav's Avatar
Exclamation
Originally Posted by 2k4EvoVIII
Duration is 280
Chris
Unbelivable!!!
when will you install it man?
Old Feb 20, 2005 | 08:42 AM
  #54
yesevo's Avatar
2k4evo---can u post how-to install cams?or anyone?
please~
Old Feb 20, 2005 | 08:44 AM
  #55
yesevo's Avatar
with lots of pictures and detail info
  #56
BSREVOLUTION's Avatar
cams were very easy. do a search.
Old Feb 20, 2005 | 08:48 AM
  #57
an0ther's Avatar
280's sound mean!!
Old Feb 20, 2005 | 09:44 AM
  #58
Evo_doer's Avatar
Originally Posted by trinydex
awww man that idle is so cute...and why is the vac higher on the tomeis... is that a better thing?
Cute? never heard that before . The vac is higher on the 260 tomei's because they are smaller in lift, less time for the valves to stay open hence 280's lower vac #s.
Old Feb 20, 2005 | 09:49 AM
  #59
2k4EvoVIII's Avatar
You got it close! Its becouse the duration is lower. The lift on the tomei's is actually higher.
Chris
Old Feb 20, 2005 | 09:52 AM
  #60
2k4EvoVIII's Avatar
Unbelivable!!!
Soon as i can get my hands on a pair. Kinda rare from what im seeing. Hopefully by next month if not i will have to wait till april and get them from my japan guy.
Chris
