Hks 280 Cam Specs
Originally Posted by yesevo
2k4evo---can u post how-to install cams?or anyone?
please~
please~
Chris
lol - yeah took me a while to find the thread Chris - I emailed Japan to see what's up with the 11.8 Tomei's. And one of these days we'll get the JUN cams added to the site since we deal directly with them as well
Thanx in advance
Chris
Chris: I spoke in person to Suzumo Koyama from Jun when he was here in Panama, and he told me that there are no plans to develop other cam spec for the evo, he told me that from their R&D, that was the best that they did come with.
Chris
Originally Posted by Ted B
This also explains why installing the Pipers at the same setting will likely result in less higher rpm power and better low speed power. Why? Because the Piper cams are advanced in comparison to the HKS cams (notice I corrected my previous post to show +3/+2). Want to make the Pipers behave a bit more like the HKS? Take your HKS timing and spin the sprockets to retard the int 3 deg and the exhaust 2 deg when you install the Pipers.
Would the head have to be setup differently for the pipers vs the HKS 272's?
Appreciate the info.
From what I've seen, I wouldn't expect any improvement with the Piper cams over the HKS 272 set.
With the head set the way you have it as per your description, you should not require any other changes to run any of the available cam sets.
Originally Posted by 954DRGSR
Excuse my ignorance, but would installing pipers in an evo w/ stock turbo (10.5 hotside) and a ported head (1MM over valves, springs etc) provide any gains over an existing HKS 272 setup?
Chris
You know what? All this info is gona be dated soon. Especially with teh Evo MIVEC comming out you will be able to run the most agressive cam profile up top and have it nice and stock down low. Then you can run whatever you want.
The upcoming Tomei 280's with 11.8mm lift are supposedly designed for solid lifters.
As far a practical experiences go, drove a friend's car with Tomei 270's with 11.5mm lift and again after he swapped those cams out for some Jun 272's. End of day, the car with the Jun cams felt much stronger than the Tomei by far.
Cheers
Dennis
Cheers
Dennis
Originally Posted by 2k4EvoVIII
There is a guy that i talked to on here through Z1 that has a 650whp car and had the piper cams. He hated the way it idled and switch to the Tomei 280's. He cant stop talking about how much more the Tomei' s perform comparted to the pipers. Now you will see a difference going HKS 280's over the 272's that has been proven already. Now how do that HKS 280's stack to the Tomei 280's with 11.5 lift and the upcoming Tomei 280's with 11.8 lift? Only time will see. I do think the Tomei 280's will provide better low and mid range over the HKS 280's but i dont think you will see much of a difference. We will see.
Chris
Cheers
Dennis
Cheers
Dennis
Chris
Sorry for the bump but I am _REAL_ curious about these videos! If you can/want, please let me know if you have them and I will host them for the forum. Let me know appx. file sizes!
Thanks.
Thanks.
Chris@nolimitmotors
Evo 'For Sale' Engine Internals and Drivetrain
400
Jan 26, 2017 08:25 AM
kaj
18
May 7, 2010 08:45 PM
4ringturncoat
13
Jan 24, 2006 06:27 AM
I
too much last night
