Having Problems After Walbro Fuel pump installed
Old Feb 18, 2005 | 06:27 AM
redevo561's Avatar
Well I just put in the walbro 255 fuel pump and i got my ecu flashed for it by dyno flash. Now i hear a loud noise coming from under the car only when its running and i kno you here the pump inside the car i kno thats normal the noise under the car is like a high pitch noise is that normal ???? and when i was testing it around top rpms feels like its dying out is this due to the fuel pump not working properly ???? i kno i installed it right its a real easy install mainly plug and play but if anyone has suggestions let me kno i was thinking maybe spark plugs but some feedback will be helpful thanks everyone
Old Feb 18, 2005 | 06:51 AM
redevo561's Avatar
bump???? anyone
Old Feb 18, 2005 | 06:53 AM
zupber4930's Avatar
Well...I don't know about your dying out problem...I don't have that...but the whine is rather loud and it's more noticable then I thought it would be so that's probably how it's supposed to be unless it's HIGHLY annoying.
Old Feb 18, 2005 | 06:56 AM
redevo561's Avatar
Do you hear it outside of the car as well or just inside ? thanks bro
Old Feb 18, 2005 | 06:59 AM
zupber4930's Avatar
No...if I remember correctly you don't. I can't say 100% for sure though...my car is in storage right now
Old Feb 18, 2005 | 07:10 AM
redevo561's Avatar
hmmm thats wierd sometimes i dont hear it and sometimes i do here outside. but inside the car it isnt that loud theres a little whine but sometimes i get out of the car iand its extremely loud whine
Old Feb 18, 2005 | 07:31 AM
redevo561's Avatar
bump anyone else thanks ????
Old Feb 18, 2005 | 07:33 AM
DynoFlash's Avatar
I think you may have misinsatled the pump - did you transfer over the white platic ring to the new pump ?
Old Feb 18, 2005 | 07:38 AM
redevo561's Avatar
White plastic Ring can you help me out maybe i didnt see that thanks ??? if i recall i remember there is the rubber piece that came with the kit but i used the oem one thanks al
Old Feb 18, 2005 | 07:44 AM
redevo561's Avatar
you mean the ring that clamps down and tightens it ????? if so yes i did take that out from the old one on to the new one
Old Feb 18, 2005 | 07:53 AM
b18flip's Avatar
nope i think al means the white grommet that sits under the o-ring. Walbro's kinda sound like a hairdryer under your back seat
Old Feb 18, 2005 | 07:58 AM
Richard EVO's Avatar
I have had no problems with my Walbro fuel pump.
Old Feb 18, 2005 | 08:04 AM
redevo561's Avatar
where is this part on the old fuel pump thanks guys
Old Feb 18, 2005 | 08:08 AM
b18flip's Avatar
when i did the install yesterday...after i pulled out the stock pump, the white grommet was still on the oulet nipple, and i popped it off. BTW be carefull pulling the pump out of the housing, i accidently pulled it out too much and popped off the wires
Old Feb 18, 2005 | 08:15 AM
redevo561's Avatar
so let me ask you something on one side of the walbro looked like it was a vavle type of inlet is that where this o ring goes on ?? thanks
