Having Problems After Walbro Fuel pump installed
hmm all i remember was a rubber part that goes on the inlet side where the filter is dont recall anything on the outlet side tho im gonna have to go check my stock fuel pump in the garage if i didnt put that on what does that do ????????
Keep the OEM grommet and use that when you install the Walbro...it fits better.
If your car accelerates fine, then I wouldn't worry too much. The Walbros are loud as hell, especially if you've been running hard on the highway for a while or the tank is near empty (the pump noise echoes in the tank, making it louder).
GottaGoFaster
18
Jun 14, 2004 09:13 AM
